Hyundai Motor 2003 Elantra Logo
Posted on Jun 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much and how long to repair and replace a power steering return line for 2003 hyundai elantra?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 277 Answers
  • Posted on Jun 23, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
277
Questions
0
Helped
57969
Points
781
At dealer 1 hour min. charge plus part. hose is not a high pressure hose so should not be much maybe $5.00 for hose.
don't know what dealers charge nowadays.
call them and ask the service manager.
2017 Hyundai Elantra steering noise?
This could be caused by the deterioration of this small flexible coupler located in the steering column. The good news is you don't need to have the entire steering column or intermediate shaft replaced as most people think. This tiny, $2.00 flexible coupler and two hours of labor could be the answer to your problem.
Nov 25, 2015
Hyundai / Kia clicking noise in steering column
2017 Elantra steering "clicking" sound when turning the ...
Reddit https://www.reddit.com > Hyundai > comments > 201...
Dec 27, 2018 - It's the rubber coupler in the steering column. It's not really dangerous or hazardous as the steering still works fine, it's just annoying.
2010 Hyundai Elantra making clicking noise when turning the ...
Jan 7, 2022
2010 Hyundai Elantra - Popping sound in steering wheel ...
Feb 7, 2016
2011 Hyundai Elantra, steering wheel makes weird rattling ...
Sep 8, 2022
HELP needed - 2018 Hyundai Elantra Steering Noise - Reddit
Nov 7, 2021
More results from www.reddit.com
1helpful
2answers
What should it cost to replace both rear brake lines on a 2003 Hyundai elantra front to back
Its cheaper if u buy lines and do it yourself honestly. But you will also need brake fluid and a friend to help you bleed all brake lines
1helpful
How do i change poer assist belt on hyundai coupe 2.0ltr 2001?
Check the attached links,similar models to yours power steering belt replace.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Install Replace Power Steering Belt 2001 06 Hyundai Elantra
Accessory Drive Belts Replacement 2001 Hyundai Accent
How To Install replace Alternator Belt 1999 06 Hyundai Elantra 2 0L
2answers
Replace left front fender
Replace left front fender - Fixya
www.fixya.com/cars/t26028082-replace_left_front_fender
Dec 29, 2015 - replace left front fender - Hyundai Motor 2003 Elantra question. ...Question about Hyundai Motor 2003 Elantra. Open Question ... How do i remove left front fender clip on a Lincoln ls 2002? Jan 04, 2015 ' 2002 Lincoln LS.
Replace 2003 hyundai elantra front passenger outside door ...
www.fixya.com/cars/t17348691-replace_2003_hyundai_elantra_front
Mar 26, 2013 - Question about Hyundai Motor 2003 Elantra. Open Question.Replace 2003 hyundai elantra front passenger outside door handle. Need to replacebroken exterior door handle on front passenger .... replace left front fender.
Wrong power steering Fluid
open the oil return to the reservoir and drain out the wrong oil. refit the hose and refill with the right oil . run and turn the wheel from lock to lock to remove air and old oil. remove the hose again and repeat the process several times until clean oil comes out the return line . Refit the hose and fill with the correct oil.
3answers
I have a 2003 hyundai elantra vibration problem
get your wheels balanced at the tyre shop.adrian,,,
2answers
2003 Hyundai Elantra Check Engine Light On
Take the car to Autozone or purchase a scanner and scan it for codes. Then do the repair and use the scanner or return to Autozone and have them turn off the light.
2answers
2003 Hyundai Elantra GLS. Check engine light, code PO133
Did you use a aftermarket O2 sensor or a genuine Hyundai one? If it's an aftermarket one it may be bad or not as good as the OEM one. See here for more details and other potential causes: P0133
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
