Aquiring Signal displays for 5-10 minutes before hearing audio
I just bought and replaced the antenna for my sirius radio in my truck, however, after i replaced it my unit just displays "Aquiring Signal" for 5-10 minutes or so or however long, either way, a long time before i hear audio. Now i turn the truck off and then turn it back on 10 seconds later and i hear audio. But, if i turn the truck off for more than 5-10 minutes or so, it will display "aquiring signal" again for the next 5-10 minutes,
Re: Aquiring Signal displays for 5-10 minutes before...
It's a bad Sirius tuner. You can find them on ebay for 50 or so rebuilt and they are better than new. It's cold solder joints on the antenna input plug. Hope this helps
I heard these have a common problem with the antenna line breaking within the radio. I had it happen and replaced the radio. It's a shame since I'm sure I could have fixed it. I think it happens if the radio ends up hanging from the antenna lead. Any electronic tech or engineer should be able to check continuity from the antenna jack and find/fix it.
Yes. However, it depends on what is causing the acquiring signal message. It could be that you just have to replace the dock or antenna. But it could also mean the unit is going bad, in which case it would need to be repaired. www.tss-radio.com has a repair guy, though with that unit being discontinued for as long as it has, he may not have parts. You may have to search around for a replacement on amazon or ebay.
I'm having same problem with XM radio in new 2011 Nissan Frontier. If the temp is above 32F in morning it acquires signal within a minute. If below, stays "loading" all the way to work (30 minutes) Come out later when warmer and functions normally. Could be antenna connection or cold throws tuner frequency off slightly. Interested in suggestions as Dealer will probably need guidance.
I had the same problem. If your radio is a kit and not factory installed in your vehicle it could be the magnetic antenna on top of your car. I had mine for about two years and from moving the radio around, or docking and undocking it, the wire from the antenna broke. It was not cut all the way through but it was enough to cause it to loose the signal. Check your antenna where it plugs into the back of the unit.
Buy radio shack electronic contact cleaner (in a can) and spray a small amount on the male connector from the antenna wire, and spray a small amount on the male connector in the base of the Sportster that the sportster interfaces with. Place the antenna connector onto the base unit and remove it several times and swirl it while connected. Place the sportster into and remove it from the base several times. This usually will fix the issue. Sat signals are extremely sensitive to the slightest oxidation or dirt or whaterver on that tiny antenna connection point.
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
