Have a Pride Celebrity X scooter. I haven't used it but a couple of times (it is about 2 years old). It hasn't been charged in months and was down. I tried to charge it..it hasn't taken a full charge yet. Will not work though...the green led light is flashing..i think I counted 9 times.
If the motor is overheating, it is drawing far more current out of
the batteries than it is supposed to. Assuming it is 2 x 13v x 33ah
batteries, these are good for about 2 to 3 years on my scooter and 'wheelchair. AGM (absorbent glass mat) lead acid batteries do deteriorate over time due to battery chemistry.
Although the batteries may appear to take a charge
and the voltage 12.6volt x 2 = 25.2 volts nominal, with no load
on them, the motor controller takes a whack of current to get you going.
I have an digital voltmeter/ammeter installed on my Pride XL scooter and I was amazed how much current the motor/motor controller takes from the batteries. 50 to 80amps on startup.
If the battery voltage drops due to the age of the batteries, as the
energy is being used up from them, the current required by the
motor for rotation has to go up, and that will cause overheating of the controller and the motor. It is Ohms law plain and simple
the less voltage available-the more current required to do the
work and current creates the heating effect.
I replace my batteries every two years. Can't take a chance on
being stuck with discharged batteries.
Hi. The batteries for these things seem to go bad rather quickly when they are not used, but here is something to try..... So called "smart chargers" are what everything is going to. They analyze the condition of the battery and if everything is good, charge it. If everything is not good, according to the parameters of that charger, they don't. My suggestion is to take the battery out of the unit and try an old-fashioned analog battery charger for a little while, set to the proper voltage for the battery, of course, and monitored closely to measure the effects. If the batteries seem to take a charge, put them back in and run it a bit, then try the on-board charger again, just don't wait until the batteries are completely drained this time.
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
