GE Nautilus 24" Built-in Dishwasher Logo
Posted on Jun 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recently glasses started to finish foggy and
8 year old GE Nautilus. Recently glasses started to finish foggy and dirty. I am using Cascade. I checked and cleaned some clogs in the spinners but still have same problem. I am not sure if the upper drawer is getting sprayed/rinsed from the top correctly. Ideas?
John Riley
Level 3:
  • Master 441 Answers
  • Posted on Jun 10, 2010
John Riley
Master
Level 3:
Answers
441
Questions
Helped
138595
Points
1344
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
3answers
Dishes leave food particles on the glasses - machine is only 2 years old. We use rinse agent - Cascade gel in the auto dispenser - we use jetdry dishwasher cleaning agen monthly - jet arms are not...
Recent changes in the law prevent soap makers from putting phosphates in dishwasher soap so they're not as effective as the were even a few months ago.  Unfortunately,  the solution is more thorough rinsing before loading.
http://www.appliance.net/2010/states-ban-phosphate-laden-dishwasher-soap-1988
My 5-year old Bosch dishwasher leaves a somewhat fine grit on dishes? especially obvious on the inside of glasses. I use only Cascade detergent, use a rinse aid, don't overfill the machine, and always...
I have the same problem with mine!! It's 6 years old, and I'm running loads of dishes through twice. Even that doesn't help! And I rinse the dishes too, so I have no idea where all these "crumbs" are coming from. Will check back for updates. Hope to get this problem solved!
My dishwasher is not cleaning. It is a GE built in and the serial # is MS721122B, and the model is PDWT400P00BB. It leave a greasy feeling on the dishes and the inside of the dishwasher is dirty and...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
sart3
1helpful
Wont clean dishes,white streaks in washer,foggy glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
3helpful
2answers
Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
2helpful
4answers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
2helpful
GE dishwasher GSD2200G00WW dishes not clean
Make sure the spray arm is actually rotating and the jets aren't clogged. You should be able to hear the arm rotating when the dishwasher is operating.
Otherwise, perhaps the pump is plugged or not working and the water isn't "jetting"
Grit like residue after cycle finishes.
I had the same problem and it was fixed by switching dishwasher soap. We always used the same liquid soap for years and when this problem came out of the blue (about 8 months ago) I switched to Cascade action pacs with Dawn. It did the trick! No more residue since then. We now are having a problem with the dishwasher not draining (our unit is 8 years old), but the grit issue has been handled!
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
