20 Most Recent
Viking DFUD04 Built-in Dishwasher Questions & Answers
My Viking Dishwasher is about 7 years old and it
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Wont clean dishes,white streaks in washer,foggy glasses
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Viking Dishwasher Leaks Into Base
Since this was posted in May I guess it's been fixed but for those of you seeing this problem for the first time, here's one reply:
This sounds exactly like the problem I just found with my DFUD042. There is a small black hose between the base of the tub and a pump motor - part number on the hose is 8072888. The hose has a small **** or crack in it and water is leaking which is most likely the problem causing the symptoms. I had to throw the circuit breaker to get mine to shut off as well.
When I tried to remove the plate it was stuck under the black sound proofing so I had to work around it a bit until it finally came off. Now I just have to find the hose and some clamps.
Viking VDW302SS--trying to pump out water that isn't there
If your machine is trying to pump out water that is not there, check the float level sensor. That is the detector that checks for water level during filling. If the pipe/mechanism is blocked, in the full position, the sensor will indicate that there is still water to be pumped out ... that is assuming the water has been pumped out otherwise look for a blockage in the outlet pipe.
3/12/2023 8:07:32 PM •
Viking...
Answered
on Mar 12, 2023
