I have a similar problem with my Timex Marathon 27 Lap digital watch. I presume the remedy should be similar. I, however, want to change from the 24 hour clock to the standard time presentation.I have a similar problem with my Timex Marathon 27 Lap digital watch. I presume the remedy should be similar. I, however, want to change from the 24 hour clock to the standard time presentation.
AnonymousSep 30, 2008
i just can't figure it outi just can't figure it out
You can't post conmments that contain an email address.
Possibly, you could push the hour-setting button through either the military or standard time setting, i.e., there are actually 48 "hours" you can set your watch to and you need to cycle through enough of them to reach the standard or military hour you want.
Press the lower left button to change the mode, make sure that you are in timekeeping mode. Press the lower right button to toggle between 12 and 24 hours. Note, with 12 hour format PM indicators will appear in the left of the hour digits.
To know more about instruction on your watch, click on the link.
To change between 12 & 24 hour display, press the mode button (bottom left) and then the bottom right button to change format. Press mode until normal display is achieved.
This manual will help
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
I think these are the directions you need
2.0 Alarm and Chime On/Off
2.1 In Normal Display hold B-Button,and push A-Button once:
Chime will be on.
2.2 push A-Button once again: Alarm will be on
2.3 push A-Button once again: Chime will be off
2.4 push A-Button once again: Alarm will be off
2.5 Release B-Button, the Display changes to Normal Display
immediately.
Had same problem. Press and hold C (mode) until the display flashes. Then press C again (without releasing) to get to time. Press "Select" to move from sec, min, hours, days, etc. Press advance to go change the actual time.
these directions work
if you change the following:
C=C Mode
A=Select
B=Advance
Normal Time Setting
5.1 In Normal Display, hold C-Button for more three seconds
and then push C-Button once. Tuesday flag and seconds
digits will flash. Push B-Button once to reset the second
to zero.
5.2 Push of A-Button once: Minute digits flash and advance by
depression of B-Button
5.3 Push of A-Button once again: Hour digits flash and advance as above.
5.4 Push of A-Button once again: Month, digits flash and advance as above
5.5 Push of A-Button once again: Date digits flash and advance as above
5.6 Push of A-Button once again: Flag of weekday flash and advance as above
5.7 If push of C-Button during any changing time, Normal Display will be
appeared
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work): http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSINGRESET/LIGHT ONLY WHEN THE HOURS MARKER IS FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE WATCH IS SET TO 24-HOUR TIME.
