20 Most Recent Timex 27191 Wristwatch Questions & Answers
2answers
Indiglo does not work after changing battery
On a Timex a lot of times the back has to be on for everything to work. But I am going to assume the back is on. The indiglo could just be out. Timex repairs their watches for little or no cost. You would have to mail it to them for repair as they do not release parts to anyone. I believe their number is 1-800 for time
10/16/2023 9:22:40 PM • Timex 27191... • Answered on Oct 16, 2023
3answers
How to clean a twist-o-flex watchband
If you can take the band off the watch do it, if you can't that's ok you just have to be a little more careful. I take a 1/2 cup of HOT water, 1/4 cup of Mr. Clean, and 1/4 cup of ammonia. Hook you watch on a cup so it isn't able to slip into the cup, and let it sit for about 10 min. Take a tooth brush and spread open the links and brush away! Make sure after you brush it that you rinse off REALLY good because if you don't you will find that dust and whatever will stick to the band becuse it will be sticky because of the cleaner. If you find you have anymore problem please feel free to ask. I have been cleaning jewelry , watchbands, and watch cases likr this for twenty years , it works well.
10/28/2020 3:38:41 PM • Timex 27191... • Answered on Oct 28, 2020
WR 30M Hourly Beep Disable
For my sportech wr 30m it worked exactly like vrrr6 said, thanks!!
2/16/2019 12:31:44 AM • Timex 27191... • Answered on Feb 16, 2019
0answers
22answers
Cannot re-attach back cover - WR30M
Yeah, I had this problem on a Timex Indiglo, but didn't have it on the cheap $20 watches in drug stores and discount stores. Timex puts a tighter cap on the back, probably for quality reasons, and you cannot push it together by your thumb. --This solution should work for about anyone: 1. Put the watch face down on a hard surface, but protect the crystal from scratching by putting a piece of cardboard or cloth between them. 2. Align the back and put a socket from a socket set on it that is somewhat smaller than the back cap. 3. Tap the socket with a hammer. You don't need to tap hard--even less than what would start a small nail. It may take only one tap--getting it aligned right is the key.
11/24/2017 6:05:19 PM • Timex 27191... • Answered on Nov 24, 2017
Rotary watch
Hi Janet, Follow this link. https://www.youtube.com/watch?v=WBPD80zQPRYOr smear some washing up liquid around the rubber ring on the back part.Hope this helps.Kind regardsDavid
10/17/2017 6:13:02 PM • Timex 27191... • Answered on Oct 17, 2017
0answers
2answers
Replaced battery in my Burberry watch, back cover won't snap on
I have the same problem. Did you guys find how to do it? Please let me know. M
7/20/2015 2:22:13 AM • Timex 27191... • Answered on Jul 20, 2015
I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_DownloadsUse the numbers on the back of your watch and you will have a PDF version of your instruction manual.Hope this tip helpsR/David
4/27/2015 12:42:06 PM • Timex 27191... • Answered on Apr 27, 2015
Hi Sir...Thanks. The Hairspring is pretty clean.
If the hairspring is perfectly clean (pretty clean is not good enough), then you have to observe it by using magnification eyeglass. Check out if the coiled parts are touching each other while the balance wheel is in motion. If that happens you need to recoil/repair hairspring and make coiling perfectly even. Also check out if the hairspring is touching balance wheel or coc;k. It must not touch anythining and must expand and retract freely. Coc;k is the bridge on which the hairspring stud and regulator (index) is fitted. When this is sorted but the problem still persists, get back to me again I'll guide you through the next stage of possible solutions.
2/9/2015 11:18:29 PM • Timex 27191... • Answered on Feb 09, 2015
2answers
My watch face has water droplets on the inside of
I have a burberry watch and it has water droplets in it but its only the middle that's full of water dropplet
1/20/2015 2:45:33 AM • Timex 27191... • Answered on Jan 20, 2015
0answers
0answers
Serial no 2674
Be the first to answer 8/20/2014 3:00:53 AM • Timex 27191... • Posted on Aug 20, 2014Be the first to answer
0answers
WR30M
Be the first to answer 7/10/2014 3:04:25 AM • Timex 27191... • Posted on Jul 10, 2014Be the first to answer
0answers
Timex 27191 Wristwatch Logo
342 questions posted
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
watch face water droplets inside
  • Watches
