Samsung ML 1610 Laser Printer Logo
Posted on May 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My problem is online error
How can i solve thids problem
Anonymous
Level 2:
Habit-Forming:
  • Expert 33 Answers
  • Posted on May 30, 2010
Anonymous
Expert
Level 2:
Habit-Forming:
Answers
33
Questions
0
Helped
7475
Points
119
Check the cable between printer and computer may be the cable is corrupted
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
655
Points
Hi guys;
Have a problem in my photocopy machine model; SHARP AR 1585 that displays Error Code H4.
1. What`s the Error code means?
2. How can I clear this Error code?
Thanks for your helps.
Hi, I have an gestetner ricoh mp2000 printer. and It shows this error out of toner. follow instructions. inside and replace toner.
http://www.fixya.com/answer/answerpageslideview.aspx?thid=27069781&ctg=459&brd=299
HiI have mp2000 ricoh printer It shows this error out of toner what should...
How do i solve thermal sensing erro on ibm t43
See my answer here:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=8&fml=0&brd=228&p=2&thid=24357750
How to fix error report script on thid page
You might want to post this question in a different section. This is the computer section......
Good Dear My minolta DI 2510F printer is giving an error when i scan. error : "communication error occured"
Duplicate of: http://www.fixya.com/postanswer.aspx?thid=8596813&prdid=445352&ctgid=6&ref=unslt
1991 Mercury Topaz engine stalls while driving...replaced temp sensor regarding pumping fuel...but that didn't solve problem. Any ideas?
Hey check out my thread, see if we are having the same problem, sounds familiar possibly.
http://www.fixya.com/ThreadAsker.aspx?thid=7662591
3helpful
2answers
Dim screen
Easily solved problem, if you are used to doing solderin on small curcuit boards. Please see:
http://www.fixya.com/PostAnswer.aspx?thid=3893007&prdid=89344&ref=unsl
My konica 3331 is giving me an error code 36-C1 ,what should i do.
thid is a fuser error code causes could be heat lamp, thermistor, thermofuse or circuit board
Epson Thermal printer (TM-T88IV) installation on Vista 64 bit OS
Two solutions are available online, at:
http://www.fixya.com/ThreadView.aspx?prdid=629594&thid=855368
Printer error
If it is the dreaded Service error, the SSC utility may or may not work but the 340 350 Adjustment Program will. Key to it after you install it is to set you computer date at February 1, 2007 before opening because the program expires on February 22, 2007. The first time you open it you must also close and delete a folder that it creates each used called ADJUSTMENT PROGRAM. Google it.
Also, if it is a WASTE PAD PROBLEM, it won't be solved just by resetting the counters. I did the "pull the hose out the back and ran the hose into a baby food jar" for my R200 and haven't had the problem since. Found directions for thid on fixyourownprinter.com. Just did the same for my R340.
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
