Nikon D50 Digital Camera Logo
Posted on Apr 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon D80 Autofocus problem
My Nikon D80 Auto Focus stopped working, when I use it with the "Nikon DX AF-S NIKKOR 18-135mm 1:3.5-5.6 G ED lens". The auto focus seems to be working fine with a Quantaray 55-200 mm 1:4-5.6 lens.
I purchased the camera & the 18-135 mm lens as a kit more than a year ago.
Can you suggest how to fix this problem prolem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
842
Points
0
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Apr 11, 2008
Anonymous
Expert
Level 2:
Answers
104
Questions
Helped
37115
Points
130
Sir, replace ur lens image reading sensor
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
4helpful
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
I have a Nikon D80 with AFS nikkor 18-135 lens, the problem is the camera doesn't make auto focus.
set the autofocus swith in the camera beside the lens to AF, and in the lens switch to AF
Autofocus stopped working
I fix these all the time for this problem, The focus motor is bad, Tony
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
1helpful
Nikon 18 to 55 lens wont focus
Check to make sure the manual focus/auto focus switch on the lens is set to A. Make sure the lens is completely mounted to the camera and locks securely. If this does not help, or if the lens was dropped, then you should consider buying a new lens. the cost of fixing the old lens may be at least half of the cost of buying a new one.
1helpful
Nikkor af-s 18-200 VR not focusing
Please check your focus settings in the camera menu. Play around with the focus point from Single to 11 points. Also, try Auto mode as a quick way to test if the focus is working
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
