20 Most Recent Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Questions & Answers
Have you read the D5300 manual? If you do not have one, follow this link for a downloadable copy from Nikon: http://download3.nikonimglib.com/archive1/nDjd000XOIQF00mktpj7624w9V96/D5300RM_(En)01.pdf
Nikon Nikkor... | Answered on Jun 18, 2019
You dropped it, you broke it. Nikon can repair, but probably not under warranty.
Nikon Nikkor... | Answered on Jan 03, 2018
When the lens moves in an out it is TRYING to focus. In some conditions the auto focus gets confused. Move your field of few and press the shutter button down half way to lock in focus. Then move it back (to original view) and finish taking the photo (pressing down the rest of the way).
Nikon Nikkor... | Answered on Dec 22, 2017
Many lenses with small maximum apertures (in your case f5.6) have difficulty focussing in low-light situations. Doubt there is a problem, unless if happens in brightly-lit situations - try some test shots on objects out of doors in the sunlight, where there is plenty of visual contrast for the lens to focus on (window frames in a building, for instance). HTH
Nikon Nikkor... | Answered on Sep 04, 2017
The Iris. Just think of your eye.
Nikon Nikkor... | Answered on Jun 08, 2017
Try this site... http://www.dpreview.com/lensreviews/nikon_18-55_3p5-5p6_vr_n15/
and this site...good luck....oh...can can buy it on EBAY.
Nikon Nikkor... | Answered on Mar 11, 2015
DO other lens work ok? DId it click into place? Try twisting it gently right and left to see if the warning goes away. If so, you have tolerance or dirt issues. A visit to your local camera shop might be helpful.
Nikon Nikkor... | Answered on Feb 06, 2015
You need to send your lens to the Nikon USA repair depot. Don't try to fix this yourself or it will cost you even more to have it put back together. Follow this link for information: Scripting must be enabled to use this site
Nikon Nikkor... | Answered on Sep 05, 2014
hello,first off,please do read through the manual that came with the camera,and at first have it close by as you go through the basic's of turning on the camera to all the way to the medium-to-advanced level guidance from the manufacturer.what you do need to do is,simply leave any control's(buttons/switches etc)well alone,until you are quite conversant with their purpose.it may well sound obvious to the casual browser who happens to read through my notes,but they are important.with the focusing ring,it may well be ok,and not suffered any undue damage.when you have gained a little expertise with the various controls,aim your camera at a distant object,and focus there with the auto focus feature,keeping your finger on the button,have a look at the barrel,to see what distance scale it has rotated to,and see if it is approximately correct,or simply measure from that point with a builders tape measure.hope that helps, cheers.
Nikon Nikkor... | Answered on Jun 25, 2014
This lens has an electrical motor inside to do the focusing. So a motor problem is a lens problem. when you mount the lens on the camera a number or electrical contacts are connected to the power supply in the camera body, this gives the electric motor it's power to operate. make sure all the little contacts are clean and that they push in and bouce back out on the lens mount area. You;ll see them there are usually 7-10 of these little silver colored contacts, they are spring loaded so the float in and out to make good contact with the camera body. If they are ok, then you needto make sure your camera or lens is not set to manual focus. I know this is elementary, but, hey, I've done it myself. both the camera and the lens need to be set to "auto " focus. the lens has a button on the side, should be set "M/A". the camera (depending on which nikon you have, will have a button on the front of the camera marked "C. S, M" or similar, some only have two settings. it needs to NOT be on "M" for manual focus. that should do it unless you have a repair problem with the camera of lens, it could be either.
Nikon Nikkor... | Answered on Apr 18, 2014
This is because the aperture varies with the focal length. Note the "f/3.5-5.6" in the lens designation? This means that the maximum aperture is f/3.5 at 18mm and f/5.6 at 55mm. If you set the aperture first and then zoom, the aperture could change by as much as one-and-a-third stops.
To prevent this, zoom first and then meter the exposure.
Nikon Nikkor... | Answered on Oct 18, 2013
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Nikon Nikkor... | Answered on Jul 27, 2013
The Nikon Lens 18-55 wide angel inner lens loosens locks lens no picture
Nikon Nikkor... | Answered on May 11, 2013
there must be a problem with the lens ring which are fitted inside, occasionally it gets worn out because of improper handling . alignments may have caused you the problem. but once again you need a professional help because you wont get any elements or parts easily except from the company.this lens could also may have jammed due to any reasons, may be a foreign body or so and because the af is OK you are still getting a sharp image up to actual 45 mm which you think to be 55mm. If i were you then I would have inverted the lens and tapped gently and then check it once again or best goto Nikon service centers .
Nikon Nikkor... | Answered on Feb 06, 2013
Great, glad to hear you're all set now.
Nikon Nikkor... | Answered on Dec 23, 2012
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
Nikon Nikkor... | Answered on Sep 30, 2012
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
83 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
aperture ring won 39 t turn
  • Cameras
