I sadly dropped my camera and the clasp has broken so the door will now not close? Any ideas on how to fix? Thx
SOURCE: Nikon N65 Film Camera Broken latch
You have to replace the whole door. There is one on eBay, but you won't like the price. Find it here: eBay
SOURCE: Canon Z85 film door clasp is broken
I would spring for the clip. Mine broke in the same manner but no one told me it could be fixed, so I got a different camera. I have NEVER had a camera that took such great photos as my Z85, and wish I had hung onto it.
SOURCE: Broken latch on film door
Usually on this level Nikon it was a plastic "hook", part of the door moulding, that was retained by the latch mechanism in the body. The broken part may still be in there - if it is trip the latch and recover it with a tiny screwdriver or even a needle. If you can't find a replacement back door you can try welding the hook back in place with a low-temperature soldering iron - with the tip perfectly clean and a very steady hand - as long as the door is thermoplastic and not thermosetting. If that doesn't work bend a paperclip or similar to exactly the right shape with the free ends (roughened) long enough to extend into the plastic of the door by 4-5mm., heat the wire and push slowly into the edge of the door. There are many variations of this technique that I've used, all require extremely careful work! Best tip: spend more time thinking than doing. Good luck.
SOURCE: Back of camera will not close
Yes, the film door was always a problem on these. The entire door was usually replace since it was one piece with the latch.
I do not believe that Nikon supplies the part any more. You can check eBay for a dead camera, or possibly a new /used door.
The other option is a repair kit available from USCamera.com
