SOURCE: I have intelliflo VS+SVRS pool
There is either something blocking the suction side of this pump (blocked valve, strainer, strainer basket, leaves on main drain.) or the pump is not getting primed in the aloted amount of time. You can increase the priming time on the pump, or manually prime it, or just turn off the svrs feature temporarily until you get a good prime again. If you need the manual to figure out how to do these things, here is the link.
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
SOURCE: the pump keeps trying to prime. There is no air
Most of the time you are sawing air from thpumo lid. Hav you lubricated the o-ring in the lid? If that doesn't work, keep working your way forward and lubricate the 3 way valves as well.
