HP Pavilion 533w (P9859AR#ABA) PC Desktop Logo
Posted on May 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CD-ROM drive isn't receiving power.
My HP Pavilion 533w CD-ROM drive isn't receiving power. What should I do?
Kris
Level 2:
New Friend:
  • Expert 38 Answers
  • Posted on Feb 13, 2015
Kris
Expert
Level 2:
New Friend:
Answers
38
Questions
Helped
5565
Points
140
The ribbon cable or the connector pins might have got damaged.
Electronics Repair
Level 2:
Sergeant:
Champion:
  • Expert 452 Answers
  • Posted on May 21, 2010
Electronics Repair
Expert
Level 2:
Sergeant:
Champion:
Answers
452
Questions
Helped
71192
Points
975
Try a different power connector, if that doesn't work then it's time for a new cd-rom drive.
1helpful
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
I replace my memory on my hp pavilion 533w ,and now the power will not come on. how do I fix it?
I found a solution that was helpful to me.. thanks fixya community....for the HP 533w you can always go here on someone elses computer as another possibility: http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=90862&lc=en&jumpid=reg_R1002_USEN
hope all worked out. they seem to deal with a lot of the issues re: memory in general. Good Luck..
The cd writer/dvd tray on my hp pavilion 533w will not open. When I press the button to open the green light comes on and I can hear a whirring sound but then the light goes out and tray doesn't open....
I understand you can't find that pin hole that's supposed to be there. but just to clarify it's supposed to be on the face of the cd/dvd, not the case. also, just trying to help, did you try opening it WHILE your pc was booting up? maybe try from windows explorer and right click on the drive from that window and try eject or open option.
Pavilion 533w cannot read dvd from DVD ROM drive but CAN read CDs. A restore of Windows XP was performed using HP's non-destructive recovery option.
The combo uses two lasers - one for the dvd and the other for the cd. If the unit works perfectly on cd and at all on dvd then the dvd laser has died and the entire unit with it, it can't be fixed. Buy a new dvd writer and junk the old one.
2answers
Replace the disc drive on hp pavilion notebook
1. First of all, you need to shut off your computer . To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the CD-Rom drive, it should be about 1.5 inch thick 5 inches wide, and 6 inches long. Unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
8. Once you find the CD-Rom drive, find the screws holding it onto the chassis. unscrew those screws on both sides of the Cd-rom drive. Be careful not to unscrew any screws holding the cd-rom drive together.
9. Now, you just have to remove the cd-rom drive, carefully by sliding it either forward or backward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
10. Now that you've removed the cd-rom drive the next step is to install your new CD-rom drive. To do this, simply slide the cd-rom drive in from the front of the computer, controls facing forward. Plug all the plugs back into the cd-rom and screw everything back into place.
Upgrades for hp pavillion 533 such memory
This is everything I could find on your computer.
Base processor and speed Celeron 2.0 GHz
  • 400 MHz Front side
  • Socket mPGA478
Back to top Chipset 845GL Back to top Motherboard manufacturer
  • Manufacturer for computer serial numbers starting with KR and CH: Trigem Glendale
  • Motherboard for computer serial numbers starting with MX: ASUS IT8708F NOTE: The serial number can be found printed on the back of the HP Pavilion computer, or while holding down the Ctrl and Altkeyboardkeys, press S. A screen will pop up with the serial number.
Back to top Memory Component Attributes RAM (installed)
Allocated to Video 256 / 2100 DDR
Up to 64MB Maximum allowed 1 GB (requires replacement of the installed 256 DIMM) Speed supported PC2100 / PC1600 Type DDR SDRAM DIMM slots Two Open slots One Back to top Hard drive 60GB Ultra DMA Back to top DVD-ROM/CD-RW combo drive 16x/8x/8x/40x maximum speed Back to top Diskette drive 1.44 MB (3.5-inch) Back to top Fax and data modem Cheetah 2 V.92 Modem Back to top Video graphics Integrated Intel Extreme Graphics with up to 64MB shared memory Back to top Sound/audio Integrated AC97 audio Back to top USB specification USB 2.0 Back to top Network Integrated on motherboard: 10/100Base-T LAN interface
Does not work, meaning does not read anything.
may be lens does not work and its life is end.or clearly tell me your problem what show this when you insert cd in cd rom
Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Not finding what you are looking for?
    Top HP Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
