Most computers have a bios you access (I see you know how to get there on yours) which allows you to choose options. Being as your bios sees the new card you should be able to either select it as default, or you should be able to click (or unclick) the onboard somewhere. This model looks to be a server, so there are several pages you might have to look through to find it. My server is a HP and it takes forever to makes changes like you are trying to do. Your video card is a 16meg, which should be fine for a server. Most often you don't use a monitor on a server anyhow, they are accessed remotely. But if you still want to change the video card, the following link gives you basic information: https://www-01.ibm.com/common/ssi/cgi-bin/ssialias?infotype=AN&subtype=CA&htmlfid=872/ENUSAG05-0436&appname=USN
SOURCE: video controller disabling
That model server comes with onboard video. If you wish to use a PCI video card then all you have to do is place it in the server and the BIOS will automatically disable the onboard. If it currently has a PCI video card in it, just remove the PCI card and you should get the onboard video again. Hope this helps.
SOURCE: 1802 PCI error & Resource Allocation Failure
Hi disable the resource allocation to S3 first and then add the Nvidia card . A jumper could do this - for disabling onboard graphics .
SOURCE: I am trying to install a pcie-x1 video card on a
This should be the problem with the drivers and BIOS setting,
You can disable the current Onboard video driver by booting up your computer in safe mode and then install the drivers in safe mode. Load your BIOS setting to default and then try to install your PCI video card.
This is a type of work arround and this may help you.
No matter on Windows 7 64-bit OS. WOW technique is available on windows from VISTA, so the issue is not with OS.
