20 Most Recent
IBM Netfinity 3500 M20 8657 Server Questions & Answers
NO SOUND?!?!?!?!?
Dear
JTBB,
It sounds like your server didn't come with sound capabilities. In my experience working with servers, I find that many of them do not come
equipped with an internal sound card. This is most likely the case with yours. If you have a few extra dollars to spare, my suggestion would be to purchase a sound card from a discount computer parts store. I like to shop
online at "
Tigerdirect.com". There parts are very inexpensive, yet they are of good quality. You can get a good sound card there for as low as $9.99. Creative labs makes good sound blaster cards.
I hope this helps, let me know if I can assist you further.
Network & Speed Problem
I suspect that the network interface card failed, & that's why you get the error message. Try disabling it from the BIOS & see if the error message disappears. If it did, then you have a failing network interface card & need to install anew one.
Running Non-ECC Ram in a IBM Netfinity 3500 M20
Dear NickB,
In my experience working with many servers, Non-ECC memory will not work on a machine that requires ECC memory. It is possible in some servers to disable the ECC mode in the system BIOS to allow non-ECC memory to work, but you will often end up with performence problems later on.
Hope this information helps, let me know if I can be of any further assistance.
Server guide for the 3500m20
Have you tried http://www-304.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=SERV-GUIDE&brandind=5000008?
It may have what you're looking for.
The vrm for my 3500m20
i am using a compaq vrm for my 3500 m20:
the number is:
320266-01
spare:329267-001
this one works!!
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology.
A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Two cpu's
The dummy voltage reg is just to complete the power loop, (as there is built in diags in the box) without the dummy the box will log errors against the empty volt reg slot.
YES you do need the Voltage regulator for the 2nd slot if you intend to install a processor there.
Video controller disabling
That model server comes with onboard video.
If you wish to use a PCI video card then all you have to do is place it in the server and the BIOS will automatically disable the onboard.
If it currently has a PCI video card in it, just remove the PCI card and you should get the onboard video again.
Hope this helps.
[email protected] login
Point your web browser at
http://www.hotmail.com.
If it comes up on another account, sign out of it by clicking the avatar in the upper-right then clicking "Sign out."
If you can't get into your own account, click the "Can't access your account?" link on the Hotmail sign-in page.
SyncMaster 753 DFX 17'' CRT show monochrome image
Oh vintage 386sx? In old graphics cards, there were DIP Switches to configure either to use as monchrome mode or color mode. Did you configure graphics card properly ? Moreover try using mode command to change monochrome to color.
IBM wheelwriter 6 only types when I press hard to the keys. Normal typing doesn't activate key strikes. Is there a sensitivity adjustment on the wheelwriter 6?
The IBM Wheelwriter 6 typewriter does not have a user-adjustable sensitivity setting for key strikes. However, the issue you're describing might be related to the keyboard mechanism, individual key switches, or the impact solenoid. Here are some steps you can take to troubleshoot and potentially resolve the issue:
- Clean and Lubricate: Over time, dust, dirt, and debris can accumulate inside the typewriter, affecting key movement. Try gently cleaning the keyboard area, especially around the key switches and mechanisms. Additionally, applying a small amount of appropriate lubricant to the moving parts might help improve key movement.
- Key Switches: Each key has its own mechanical switch underneath. If a key requires more force than usual to activate, it could be due to a worn or dirty switch. You might need to disassemble the typewriter to access and clean the key switches.
- Impact Solenoid: The impact solenoid is responsible for striking the print head against the paper to make an impression. If the solenoid is weak or sticking, it could result in the behavior you're describing. Try cleaning and lubricating the solenoid. If the problem persists, the solenoid might need to be replaced.
- Key Flex: The flex you feel in the keyboard might be contributing to the issue. If the keyboard has any physical damage or if the flex circuit is not seated properly, it can affect key activation. Carefully inspect the keyboard area for any visible damage or misalignment.
- Professional Repair: If the above steps do not resolve the issue, it might be best to seek the assistance of a professional typewriter technician. They have experience with these machines and can diagnose and repair mechanical issues more accurately.
I have a IBM personal computer Platinum III When I turn on my computer it starts normally but after that on my screen appears a text that says "System Error: tastiera Blocked" And after I can't continue to boot and it shows on my screen a error without a code...What should I do??
Tastiera indicated that you have a keyboard problem. Most desktops can't run without a working keyboard. (You need the keyboard connected and working during the power-on self test, POST.) Currently the motherboard can't communicate with the keyboard.
What is the model number for your computer? I don't recall a Platinum III, just a Pentium III. Is it a laptop or a desktop? What type of keyboard do you have (USB or PS/2 connector) or is it the built-in one of a laptop? Are you using some sort of converter/adapter for the connections? The USB to PS/2 converter for a mouse does not work with a keyboard. There are some USB to dual PS/2 converters available. However, they don't work with with all motherboards. What OS is installed on the system?
Try a different keyboard. (You should try a PS/2 keyboard if the system has PS/2 ports. If the OS is older than Windows 98 v. 2, then the USB ports are even more likely to not see the keyboard in POST.) If you use a USB keyboard, try different ports. If possible, make sure that the keyboards work on other machines. If it does, then I recommend replacing the system. The Pentium III is a ~20 year old CPU. That's certainly old enough to have major failures.
I hope this helps.
