Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Normal
0
false
false
false
font-size:10.0pt;
The filter on your pump is probably clogged with lint and
stuff. You have to remove the bottom front panel, 3 torx screws underneath. The
panel will drop and come off. Drain off the excess water from the hose you
see. The white filter cover is right in front.
Get yourself a bunch of towels or a good big plastic bag to collect water.
Unscrew the filter cover and twist the filter out. Clean out all the stuff and
put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be
stuck around the inside tub of your washer. Try this product, it works great on
all front loaders. Use hot water with the Affresh pellet with no clothes and
run the machine through a cycle. Also
helps with any stagnant water smells. Have you cleaned out your pump
lately. Put the pellet inside the
machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Opening the front panel, which was a total pain, worked like a charm. The filter was filthy and had a sock in it. Once I cleaned it, the washer now drains perfectly. However, the plastic on the inside of the washer is coming off and the drum doesn't roll as smoothly. Very loud. Thanks to all..
