Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
A
Anonymous Posted on May 17, 2010
D40 Digital Camera with G-II 18-55mm Lens: How do I get the shutter down again? I keep gettin...
How do I get the shutter down again? I keep getting the error message: error press shutter release button again
Anonymous
Level 2:
New Friend:
  • Expert 159 Answers
  • Posted on Jan 23, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
159
Questions
0
Helped
47462
Points
284
1helpful
2answers
I have an error massage in my nikon d40 lcd screen "error press shutter button again" how can i get rid of it?
Press shutter button again. If the error doesn't go away, take the camera to the authorized dealer repair shop.
Error:press shutter release button again
You can try removing the lens and putting it back again but if its still giving you the error message, you need to have the camera repaired by a technician.
3answers
D40 Nikon
i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
Nikon D40 will not focus when shutter pressed 1/2 down
has the lens stuck up? put it temporarily on 'M" and try to turn the focus ring. this should be freely turning;
otherwise you may want to check the camera body to lens electrical contacts (silver).. a small dab of alcohol to a q-tip.. make sure its not that wet..then try to clean the contacts.
My d40 gives error message "error press shutter button again"
When do you get this message? Is the Mirror Lockup on? If not, try to take the lens off and screw it in again.
R 07
Certainly sounds like the mirror is stuck or even been dislodged.
3answers
Nikon D40 shutter speed problem
The D40 will not take great photos of an indoor event without blurring or noise. You need a fast lens and a high ISO using the popup flash or on camera flash would be ideal but some of these events you can not use flash. All these images I shot with a Nikon D40. http://www.facebook.com/home.php?src=fftb#/pages/Keller-TX/Raving-Design/78762448229?v=photos&ref=ts Learn to use the camera for ur events. Experiment it's all about trial and error. Ray
14helpful
9answers
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
