Question
Setting the clock
Answer
To select the type of
clock that is shown and set the time, tap
Change preferences
Set clock.
This feature is only available on your navigation device. You cannot
use this feature in TomTom HOME.
- The easiest way to set the time is by tapping the Sync button.
Your navigation device will then take the UTC time and date from GPS
information.
Note: You can only use Sync if
you have GPS reception, so you cannot set the clock in this way when you
are indoors.
- Adjust the hours depending on your time zone. Your navigation
device works out your time zone and always keeps the time correct using
GPS information. You only need to adjust the daylight-saving time.
