20 Most Recent
Tomtom XL 330 Car GPS Receiver Questions & Answers
Cannot get my tomtom xl 330s reset not enough free
If there's data (items) on your TomTom that you can remove/delete, like music, photo's, images, (useless/not needed) maps, favorites, etc. it will give you more "disk" space to work with.
You can back up the data (using the TomTom HOME application) before you remove the items from your device.
How to change the battery
The battery in the TomTom GPS device is not (readily/easily) consumer removable - replaceable .. i.e. it is not like how you'd replace a battery in your digital camera.
If you really want to, and are willing to take a chance, check this out
http://www.youtube.com/watch?v=yHOCCjaXn0Q
I have a tomtom xl 330. the device will not start
A likely cause is that the battery is "dead" ... i.e. no longer holds a charge. The GPS runs on battery power, even if it is plugged in. It will work even if the battery holds a (small) charge. But if the battery doesn't a charge anymore, the device will not start up, even when it is plugged into a power source.
If this is the case, you'll want to change the battery.
Error message?!?!
If this is a firmware update, use MyTomTom application and delete the firmware and try again.
How do you charge the battery?
You can use the car adapter, or you can connect it to a USB port on a computer. You have to let it charge for a few hours.
How do u reset tomtom go 910
On the back, where the mount goes will be a small button, press this in with a pin or such like, this will reset it
I have a little used TOM TOM XL 330--I LIVE ON
To get the address/location of the nearest repair center, kindly contact TomTom customer support helpline on this number:
866 486 6866
Timings:
Monday - Friday: 7:00 a.m. to 11:00 p.m. EST
Saturday: 9:00 a.m. to 8:00 p.m. EST
Thanks for using FixYa.
Lost my user manual and would like another
You can download and print the manual in PDF format from the manufacturer's support website by clicking this
link.
On the page which opens, click the "
XL 330/325 Reference Guide" link to download the manual.
Adobe PDF Reader is required to view this manual.
Download Adobe ReaderHope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using
FixYa.
I tried to update my unit and got an error message
Quote:
We're
sorry, but HOME can't complete that task. Please try again later, or
contact customer support. For problems with items that are stored on
your device, we advise you to remove and re-install the item.
END
To make a long story short, the problem was with the map that is stored
on the computer from downloading the latest map guarantee (2 1/3 years
ago). In my case, this is the same map as is on the GPS, but it is not
complaining about the map on the GPS. If this happens, there are several
things that can be done:
1. Accept the message whenever it appears and go on with what you were
doing since at least most functions of Home appear to work correctly in
spite of it saying that it can't complete the task.
2. If you have a backup of the previous version of TomTom Home, replace
the updated version in the Applications folder with the backup version.
This will return behavior to what it was before the update, without the
error messages.
3. Remove the map folder (e.g., USA___Canada) from your
Documents->TomTom->HOME->Download->complete->map folder.
You may want to save this someplace so that you can put it back when
TomTom releases an update to Home that works correctly.
Hope helps.
How to change language
FRom the main menu tap Change Preferences then tap the arrow in the bottom right corner until you will see the Change language button and tap on it. Tap the language you want to use.
No maps after update and map download
Locate the "Power" button. It's on the top right-hand corner ofeach device.
Hold down the "Power" button until the device resets. TomTom notesthat this reset process can take more than 15 seconds.
Release the "Power" button once the device resets.
Now update it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
How to get it to be in english
- In driving view, tap the map to open the Main Menu.
- Locate the Preferences icon and tap it. Depending on software version, it looks like a wrench or a gear.
- Cycle through the menu pages until you see an icon with three flags (UK, German, Dutch) and tap it.
- From the list, select your preferred language.
