20 Most Recent
Nextar X3-03 Car GPS Receiver Questions & Answers
Gps update
You go to the Nextar web site, and usually you have to register, then you connect up your GPS, to the PC via USB cable, run the software and then you will be able to download anything you wish from their web site onto your GPS.
X13-12056
hi. brought this satnav second hand with no instructions and disc ( person could not find it all ) want to up grade maps and cant, got hold of seller and guess what they can't remember pin number.
so can't up grade maps, how can l unlock pin no' etc.
thanks geoff.
APPLICATION INTELLNAV.EXE HAS PERFORMED AN ILLEGAL
Was the SD map card specifically designed for your GPS model number?
You'll want to double check since map cards are not universal. Even if you load updated IntelliNav maps onto an SD card, it usually just crashes.
My Nextar X3-03 GPS just died, cannot turn it on, on button will not depress. Bought this @ Kohls in 2010. Thank you!!!
Unless you know how to replace the on button, I don't think there is much you can do. You need some skills, to open electronic devices, in a way you can put it back together in one piece.
Could be a spring in the switch is broken or the contacts are defect. But you have to open it to see what is wrong, so you can replace the defective part. Be aware it can be difficult yo get spare parts. Don't know what a new one with brand new maps will cost, but there are great (cheap) ones on the market now. Check that too. Success..
I could use an update
update available here:
http://www.nextar.com/frontend/proddetail.asp?pn=PART-GPS-MAP09SDC2
Have nextar from 2008 do
While using the Nextar GPS device, if you need to update the map you can do it. Generally all Nextar GPS Receivers comes with preloaded map for USA and Canada.
To update map visit Nextar.com and under product info, you will find the map update option.
Losemycaradapter
They are pretty cheap at Amazon...http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=Nextar+X3-03+Car+GPS+charger
Can maps be updated?
Dear Joe Kunec,You should be able to download additional data to your device if you have a slot for an external memory card. The best way to find out how possible this is, is to go to the website or phone up the people who manufactured your device. If no joy, check some of the other forums and see what people say, but as a general rule. All devices made within the last 4 years, should allow you to update the software.I hope this is the fixya for you and I look forward to hearing from you soon.Yours sincerelyOuszen
Chip update
If any updates are avaiable they will be at the Nextar GPS product support site.
