Compaq Presario CQ60-220US PC Laptop Logo
Posted on May 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I format C drive with windows 7 on it I want to put windows XP on
Matthew Albert
Level 2:
  • Expert 281 Answers
  • Posted on May 16, 2010
Matthew Albert
Expert
Level 2:
Answers
281
Questions
37
Helped
149824
Points
843
If it came with win 7 then you may have a varry hard time finding XP drivers for that system, It will most likly not work with win xp,
If you reformat to XP you may loss your HP restore!!
If it dont work and you cant restore it.. then you will have to pay for a HP restore disk or new windows 7 disk.
That said to do it you will need a windows XP CD..
Put win XP cd into your cd/dvd, and boot to cd,
This will start the windows XP instal and give you the option to reformat c drive and instal win XP
Mehandi Husain Suleman
Level 3:
  • Compaq Master 1,654 Answers
Compaq Master
Level 3:
Answers
1654
Questions
Helped
576993
Points
4530
Hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
1helpful
Data on clickfree is from my old XP, when i connect to my newer windows 7 computer, it wants me to format.
Win 7 doesn't recognize the format of XP drive. Put the Click drive on an XP machine on the network and copy files you need then format on Win 7 machine.
Format hard drive
Hi
To "format C" means to format the the C drive, or the primary partition that Windows or your other operating system is installed on. When you format C, you erase the operating system and other information on the C drive.
However, it's not a straightforward process to format C. You can't format the C drive like you can format another drive in Windows because you're within Windows when you perform the format. To format C from within Windows would be like lifting a chair in the air while sitting on it - you can't do it.
The solution is to format C from outside of Windows, meaning you need a way to format a drive from somewhere other than your Windows installation. The easiest way to do this is to boot to an operating system (with formatting abilities) from a CD/DVD/BD drive, flash drive, or floppy drive.
This might all sound very complicated but it's actually quite easy to format C. Below are 5 completely free ways to format your C drive:
Note: If you're trying to format your C drive because you want to replace or reinstall Windows, you do not need to format C ahead of time. Formatting is done automatically during the Windows installation. Skip this article entirely and instead see How To Clean Install Windows.
Important: Formatting your C drive does not permanently erase the data on the drive. If you want to completely erase the information on the C drive, see Option 5 below, Wipe the Drive Clean With Data Destruction Software.
1. Format C From a Windows Setup Disc
The easiest way to format C is by completing part of a Windows installation. It's not easiest as far as number of steps goes, but since most of us have a Windows Setup DVD lying around, we have easy access to a means to format drives outside of Windows.
Important: You can only format C this way using a Windows 7 Setup disc or a Windows Vista Setup disc.
However, it doesn't at all matter what Windows operating system is on your C drive, including Windows XP. The only requirement is the disc you use to format C - either a Windows 7 or a Windows Vista Setup DVD. Feel free to borrow a friend's disc if you'd like to try this method but you only have Windows XP... or some other operating system.
2. Format C From a System Repair Disc
If you don't have access to a Windows Setup DVD, but you do still have access to a working copy of Windows 7, you can create a System Repair Disc and then boot to that disc and format C from there.
You can only format C using a System Repair Disc if you have access to Windows 7 to create the System Repair Disc. If you don't have access to Windows 7, find someone who does and create the repair disc from their computer.
Note: A System Repair Disc created from Windows 7 can format a C drive that has any Windows operating system on it, including Windows XP or Windows Vista.
3. Format C From Recovery Console
If you have a Windows XP Setup CD, you can format C from the Recovery Console.
The biggest caveat here is that you must also have Windows XP installed on your C drive. However, if you don't have access to Windows 7 or Windows Vista, this option may be your best to format C.
This Recovery Console method to format C also applies to Windows 2000. Recovery Console does not exist in Windows Vista or later, nor does it exist in Windows ME, Windows 98, or earlier.
2answers
How can i format the expansion drive
@swaroop_2k6
You can let windows format the portable HDD by doing the following:
For XP / Vista / Windows 7
1. Click Start > Computer (My Computer for XP)
2. Right click on the Removable Disk and click Format
3. Put a check on Quick Format and leave the other settings to Default and click Start
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
2answers
What Windows-compatible "backup" software can
You can format it directly from Windows XP going in My computer then right click on your drive icon and hit format. Don't change anything in the fields but put a check in quick format.
For your backup needs, Acronis are making very good data management softwares.
1helpful
2answers
I have window xp professional on two drives ie C and E, Now I would like to delete the xp professional from Drive E. How to do that
This will erase everything on the E Drive
1. Go To my computer
2. Locate E drive
3. Put the mouse over E drive
4. Right click
5.Choose Format
6.Check Quick Format
7.Now you have a empty Drive
Thanks
DiegoTech
I am using windows 7 in my compac 320 laptop but can not install windows xp! How can I install it in my laptop?
7 is far better then xp... but if you want to put xp on, format the drive using xp, you need the laptop to boot from rom drive 1st, set it in bios...
2answers
I bought a acer aspire 5542g with window 7 on it
You will have to boot of the XP install disk and reformat a FULL NTFS format, first, that will enable you to wipe the drive and install XP. To save an email, or any file to a flash drive, simply copy/paste or drag and drop onto the drive, the drive must be Formatted first, format FAT32. OR when asked for location to save, point it to the flash drive as normally done.
My hitachi hard drive dosent show up in my computer
The reason it's not showing up in XP is because microsoft made updates to drive handling in Windows 7.
The disk is in essence too "advanced for XP"
Your best solution is to copy the data off the drive onto the windows 7 machine, then format the drive using windows XP. Once formatted, copy your files back onto the drive from the windows 7 computer and both will be able to share the drive.
Hope this helps FixYa,
Crankstart
favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico Rank: wait... favicon.ico Traffic: wait... favicon.ico Price: wait... favicon.ico C: wait... close.gif
Can't open my sandisk cruzer 16gb
i have a 16 gb pendrive which is detected in my mac but not in any windows...............help me out here
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
