The oven is over 35 years old and the lower oven does not turn on. I guess the element is either burned out or is not being activated by the dials. the model/serial numbers are as follows: REG 77HB*0- 90GM 8098 Is this part easy to replace by myself and would this part be available. thanks
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
