20 Most Recent Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Questions & Answers
check broiler ignitor
Frigidaire 27... | Answered on Oct 08, 2017
bad temp sensor
If the elements are good and you have checked the obvious connects etc. then it would seem to be the control circuit.
Frigidaire 27... | Answered on Sep 22, 2017
you have to let the oven dry and clean and you should not put any oily foods on it..
Frigidaire 27... | Answered on May 12, 2016
Hello - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Frigidaire 27... | Answered on Jun 02, 2014
Hello Duane, I am happy to assist you. Typically, error code F4 indicates a lockout error. Try resetting the unit by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) or the Lockout Control Board on the appliance will need replacing.
Frigidaire 27... | Answered on Aug 20, 2013
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
Frigidaire 27... | Answered on May 31, 2013
Hello Brent Delong - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Frigidaire 27... | Answered on Mar 12, 2013
Hello mapatt - Are you able to open or latch the door? Try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. This will clear most false error codes. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs. The unit could possibly be experiencing a wiring failure, faulty light switch, door latch or EOC.
Frigidaire 27... | Answered on Jan 30, 2013
Hello tony sunlitis - I understand that you would like to know how to replace the light bulbs in your unit. So I can assist you better in pinpointing you the information, may you please provide me the model number.
Frigidaire 27... | Answered on Nov 29, 2012
try this site http://www.manualsonline.com/
Frigidaire 27... | Answered on Feb 27, 2011
Have you tried to unpulg it and see if it unlocks
Frigidaire 27... | Answered on Jan 01, 2011
Frigidaire 27 in. Electric Double Self-Cleaning Wall Oven Logo
54 questions posted
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
instruction manual leeb30t9fea
  • Ovens
