I have a sansa 280 when i clicked to play a song last night it went back to the "Sandisk" turn on screen and then it faded out..it turned greenish then redish and then was just a black screen. i couldnt do anything buttonwise so i layed it aside to let the battery die..this morning i connected it to the computer and it still did the same thing it wont get recognized on the computer and it doesnt say anything on the screen other than sandisk for a full 3 seconds or so until it fades out..im not a happy camper to say the least
Download the Sansa firmware upgrader and install it first. Then, hold in the volume + button on your Sansa player and connect the Sansa to your computer (while it is in the OFF position). The computer will recognize the player after you continue holding the volume + button for 5-50 seconds. Restart your computer. You will lose all files stored on the Sansa, but it will work again.
ok buddy...it might be problem with the storage.. try to format the player once.. now the player will be fresh... now download all the songs and try whether its working fine... if the problem continues try to contact the player manufacturer for replacement
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Should you have any problems after you update the firmware let me know and I will be more than happy to help you...
The number for sandisk is 1-866-726-3475 Please rate accordingly Thank you Computerrep
Only 2 suggestions here:
1) Make sure your HOLD switch is not enabled.
2) Try to update the firmware
If neither of these work, time to send the unit back to Sandisk
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following:
2. change lock switch to orange position
3. Press and hold rec button (at left side)
4. while pressing the rec button, turn the player on
5. it will appear the boot menu. connect the USB cable and try to continue the firmware
6. if it doesn't work, do a firmware downgrade. download this file:
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
7. execute the application while in boot mode
good luck
darek
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
