20 Most Recent
SanDisk Sansa E280 MP3 Player Questions & Answers
Sanso Clip 2G from Windows Media Player
You may be syncing them to the wrong file. This is odd, but try fishing around the device for any "Music" folders. Then, you should be able to cop&paste the songs there. Please rate!
Can't delete duplicate tracks!
Go to my
computer scroll to sansa or your
MP3 player and open the
music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Try and drag and drop from your
music folder to the
media folder on the player make sure usb mode is msc this will show you all the folders Use your
windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer first
I have no idea how to delete duplicate songs from my sansa 280e.
You can have a try Leawo Tunes Cleaner. Just follow below steps. If you still have issues or have a massive music library in iTunes or other music folders that requires a more powerful and less time-consuming option, the third-party software like Leawo
Tunes Cleaner can help you. It can not only automatically clean up duplicate songs in iTunes, but also automatically delete duplicate songs in other music folders. If you want to automatically remove duplicates in iTunes, the automatic duplicate remover might have the answer for you.
1. After kicking off Leawo Tunes Cleaner, click the "Clean-up Duplicate" entry. The program provides 2 duplicate scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
2. You could delete duplicates in iTunes music library by directly clicking "Scan iTunes" button or click "Add" button to load music files for duplicates removing.
3. After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
For more details, check:
How to Delete Duplicate Songs
How do I delete duplicate songs from my e280 song list?
DVDs
Rip the dvd's to your computer using a dvd-r drive, use the converter on the installation cd thats included and convert them to the right format, locate your file and drag it into your mp3's correct folder [My Computer]
