Sony VAIO PCV-RX462DS PC Desktop Logo
Posted on May 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SONY PCV-rx462ds won't power up after 3 y of inactivity
Hi, I took my very old computer (PCV-RX462DS) from my old apartment and moved it to a different city where I now live. I wanted to copy all my old files, reinstall a system and give to my cousin who needs a computer just to browse internet.
To my surprise the computer won't power up: no lights, no sound - nothing. The only thing that I noticed is that when I plug it into the wall socket, a respective led lights up on the ethernet hub the computer is plugged into. But that's it. I tried to move the computer with care but who knows what happened. The last time I switched it on was probably 3 years ago.
Please advise.
Thank you!
Anonymous
Level 3:
Guru:
  • Master 551 Answers
  • Posted on May 13, 2010
Anonymous
Master
Level 3:
Guru:
Answers
551
Questions
Helped
113811
Points
1166
Please to reset all cables inside your computer. the power supply, memory modules (have it clean), the processor, the IDE or SATA cables, the video card then try it. see if it works.
My CD-ROM doesn't work
ok what you can try is go to your device manager (type devmgmt.msc in run) uninstall and reinstall cd rom drive under opitcal devices
How do i use a wireless modem on my sony vaio
type in IE 192.168.1.1 then fallow the instrection
2helpful
2answers
CD drive not working
Based on your indication the CD drive is clean, and you know the cables are attached to it, inside the computer. (Flat ribbon IDE interface cable, and 4-pin Molex connector power cable)
1.Go to Device Manager
Left-click on Start. Right-click on My Computer. Go down, and Left-click on Properties. Left-click on the Hardware tab. Go down, and Left-click on Device Manager.
Left-click on the + sign to the left of, DVD/CD-ROM drives.
Right-click right on the name of the CD drive.
(Example: Lite On DVDRW LH-20A1P.
eMachines Support indicates the T5212 has a DVD burner drive, and a CD drive. Right-click on the CD drive name))
In the drop down list, Left-click on Properties.
Left-click on the Driver tab
Go below, and Left-click on the Update Driver 'button'. Now go below, and Left-click on OK.
Close all windows, go back to your desktop screen.
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Do Not Restart. We need a 'Hard Shut Down'.
Wait 1 minute, turn your computer on.
Still doesn't work?
Let's play hard ball.
2.Go back to Device Manager. Left-click on the + sign to the left of DVD/CD-ROM drives. Right-click on the name of the CD drive. Left-click on Properties. Left-click on the Driver tab.
This time go down, and Left-click on the Uninstall 'button'. Go below, and Left-click on OK
There will be a Microsoft 'squawk box' that comes up. "Warning you are about to uninstall this device"
Left-click on OK. (It IS okay!)
Close all windows. Shut down your computer normally. (Again, we need a 'Hard Shut Down'. To Restart a computer is known as a 'Soft Shut Down')
Wait 1 minute. Turn your computer on.
After Windows loads all the way, and all of your Start Menu programs have loaded, you should see a pop-up out of your system tray. (Bottom of Windows desktop screen)
"Found New Hardware", and perhaps another one, "Found XYZ CD drive". (XYZ = the CD drive name)
No still?
The driver for your CD drive, is located within the Windows XP operating system on your computer.
If your CD drive does not work now, I suggest it has failed.
Drives such as Optical drives, and Harddrives, are mechanical devices. Their 'Lifespan', is rated in so many hours of usage. Your CD drive may be at the end of it's 'Lifespan'.
My cd-rom wont work
The laser lens needs cleaning.
Radio Shack has a CD laser lens cleaner ($13).
It is an audio CD with a row of brushes on it.
Read and follow directions. It does not use chemicals and will not harm your CD drive if not done correctly.
VAIO PCV-W510G Keyboar & mouse wont work
Hi torr3s_t,
Here is a web site where you can download your computers manual: http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVW510Ga . I would copy and paste the web site.
Here is Sony's support Number for computers: 239-768-7545 Monday- Saturday 11:00 AM-8:00 PM ET
Hope this helps,
GaWebSpinner
1helpful
Cd rom doesnt work at all
hi if ur system is provided with two drives then u can use the second drive.. if not then u have to go for a change of new rom..since u said that ur light wont even flash it means that ir drive doesnt detect that particular rom and it has got damaged....
thank u rate me
I have a sony vaio, and i can't get the combo drive to write cds. this seems to be an intermittent problem. sometimes the drive doesn't show up in my computer and when i try to load the driver, i get a...
Hi try taking the drive out of the laptop,you may have to unscrew some screws under the drive first .Make sure you have the laptop turned off when doing this.When you have the drive out put it back in firmly then put the screws back in.This may sound stupid but sometimes this is all it takes.
CD DRIVE
  • go to start
  • right click on "my computer
  • down to ,and click on properties
  • go to hardware tab
  • click on device manager button
  • click on the + sign next to dvd\cd drives
  • if a drive is present,right click on it and un-install it, if one is not present,
  • go to "actions" menu on top of the device manager box,and select "scan for hardware changes".
  • reboot and windows should find it when it boot's up.
  • if not you need a new drive
good luck
Terry
My computer wont read discs anymore
just clean it the disk cleaner, if not work
remove the cd/dvd drive into your pc then i have knowlegde how to repair it just open the casing and replace the belt in the gear then wipe the lens with clean cotton.
if not work i suggest you to buy a new cd/dvd drive because the lens of that cannot read.
Cd drive
Try having your cd drive cleaned. A cd drive could prevent the cd drive to read the disk properly. The drive noise is normal if the speed of your cd drive is high. Here are some links on how to clean a cd drive:
http://www.deinmeister.de/cdrep_e.htm
http://www.ehow.com/how_2044857_clean-cdrom-drive.html
Here is the link for reducing the speed of the disk (if the sound annoys you):
http://hektor.umcs.lublin.pl/~mikosmul/computing/tips/cd-rom-speed.html
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
