If the noise lasts beyond 2 minutes at a time (which it sounds like it does) then you have a motor problem.
I am suspecting that the main seal has leaked onto the motor and is causing water to get into the motor.
Do not use the machine anymore until to you check under the dishwasher.
-Remove the power by turning off the breaker or unplugging the power cord if accessible.
-Remove the screws holding the lower kick panel on and remove that panel
-Look for signs of water on the floor
If you see water stains or water then you need a new pump and motor.
If not let me know and we can go from there
The problem is still the same... the soleniod valve...it can do that sometimes but usually will go to the uhm and not work... however if things go wrong in the right way then you will get the horrible niose you are experiencing...
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Now I am getting SOME water in - but the noise persists. It sounds more like a motor than anything else.
Thanks!
