Not exactly sure if the model is the same but on a C351 the C9401 & C9402 errors are as follows:
16.6.81 C9401 Exposure lamp failure to turn on
16.6.82 C9402 Exposure lamp turning on at abnormal timing
Parts to check:
Scanner Assembly
Flat Cable
Image Processing Board (PWB-C)
Step Action
Corrective steps in order of suggestion:
Check flat cable for proper connection and correct or change as necessary.
Change Scanner Assembly if necessary
Change PWB
My machine is c9401 error
I would like to verify that the code you are seeing is a C9401? This code does not appear in the factory service manual and I have never seen nor heard of it before. Could you please verify the code and also that your machine is a Konica Minolta C450P as is indicated on your listing. Thanks
