How do you or can you reset colors on the monitor. Everything on the monitor looks very blue. How do you make the colors go back to normal?
1. Uninstall the monitor / then reinstall it with the software that came with the unit.
2. check and update your video card drivers
3.You also may have a faulty video inverter in the monitor and the monitor may need service.
4. You could also have a faulty video cable.
5. If you have another monitor that is known to be good and connect it then this will tell you if the connection to the pc is OK.
this will narrow it down to the monitor itself.
Try going into on screen menu and and look for factory reset on screen menu. You may have VGA cable problem or it can also be the video card. Please try this monitor on anther PC to see if the problem goes away.
