Motorola Talkabout T5500 (7 Channels) 2-Way Radio Logo
Posted on Apr 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Voice recognition on motorola t5500
I visited some site and it said that motorola t5500 two way radio has automatic voice recognition something
electronic & computer repair& servicre
Level 3:
  • Motorola Master 12,061 Answers
  • Posted on Apr 15, 2010
Motorola Master
Level 3:
Answers
12061
Questions
0
Helped
4008291
Points
36390
That means that it will Transmit, like pressing the "Talk" button, BUT ONLY when it hears the "Voice" it was "Trained" on. So this is so No-one else could use this unit. With this method. You "Identify" yourself, and after that every-time you speak, the Transmitter is keyed, and the channel is opened and the voice sent, when you stop talking,it goes back to receive, again. Some are less sophisticated, in that they are really a "Sound Switch" and when the unit "Hears" a "Voice" it, switches OFF receive, and ON the transmitter, and Transmits the audio out.
Only one works
Check your programming http://shop.giantintl.com/Manuals.asp?offset=30
I have a Motorola V560 phone. It was mine at one time and I activiated the voice recognition. Now my husband has it and wants to use his voice instead. How do I change the voice recognition feature?
I would do a master clear and delete all old data off phone. Do this by going to settings>security>master clear> sec code: 000000. Good Luck!
I’m happy to assist further over the phone at https://www.6ya.com/expert/steven_958e67a4edcc47d5
I cant get signal why?
Could be a number of reasons. These radios operate using FM, which transmit and receive most effectivel on a line of sight. If you have something physically blocking you like buildings, hills, any obstruction..., you could then have problems with reception.
16helpful
Need manual for motorola t5500 talkabout
the manual for the requested product can be found by clicking this link (you may have to temporarily allow pop ups)
T5500 Manual
The manual is in PDF format.
Please don't forget to rate my service, thank you.
Modify a motorola T5500 to work in different frequency
Sorry. The MHz of your radio cannot be changed. And there are no "private" frequencies available for use. However, your radio is equipped with this in mind.
There are 22 frequencies built into the T5500, along with 38 Interference Eliminator Codes. The two combined offer you over 836 choices to avoid other people. And if this is not sufficient, they also have the capability Qt filtering.
http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Page 19: Interference Eliminator Codes
Page 21-22: Qt Filter
Motorola T5500 Scanning problem
Most likely it is stopping at a channel which has RF (radio frequency) activity. The activity doesn't have to be another radio with someone talking. It could simply be something transmitting on the same MHz. The only way to know for sure is to try the radios in a different location (as in moving away from the problem). If you want to avoid this "noise" you can turn on your interference eliminator, and it should block out anyone transmitting on the frequency (unless they set their interference eliminator to the same code as yours.)
If the noise continues when you try the radios in a different location (more than 5-10 miles away), then you will have to investigate a problem with the radios themselves.
Motorola T5500 - can't start scan !
Hello AHAPXUCT,
To start scanning on a Motorola TalkAbout T5500 all you have to do it press the MON button for a full second and then release it. The radio should automatically being scanning the channels for activity and stopping on any received signals.
Best Regards,
Ken
"Go Ahead. Use Us."
2answers
Scan
If it does- yes, it will pick up other 2 way radios.
1helpful
2answers
Motorola Talkabout T5500 Menu button doesn't work
I think you radio has a problem and will need to be checked, rapaired or replaced.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
