When i take my foot off the pedal when transcribing, the tape moves forward instead of auto reverse. I changed pedals and it happens with all of my tapes. ???
SOURCE: Problem with playback using foot pedal
you probably have a broken pedal here is one in a great price
http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
Or if you feel better to send unit to service try this.
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
SOURCE: Sanyo TRC-8080 transcriber only When using the
Hello your unit may have a desolder autobackspace slide control or maybe your pedal is going bad here is a link for your pedal replacement http://www.tvps.com/Products/Sanyo-FS-56-Transcription-Foot-Pedal---Pre-Owned---FS56__SA-P-FS-56.aspx or send your unit to service at Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
SOURCE: My transcriber keeps going after
Does your transcriber have a digital display? If so, turn off indexing by holding down both stop and reset together for about 5 seconds. Also turn off the Auto Stop if on.
SOURCE: I have a new Sony
Hello sorry the M-2000 don't have the ERASE feature but your only option is to get a tape eraser you can get one at http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx just think positive your unit will last longer the eraser prolong the life of units just pass the microcassete once on the eraser and is done full erase :)
SOURCE: have a panasonic RR930 microcassette
If neither rewind nor backspace work, the common problem would be that the solenoid grease has dried up and the solenoid is not retracting all the way. However, the track that the mechanism moves in also wears out, as well as the plastic rocker that depresses the rewind button where it engages the metal slide.
If backspace works but not rewind from the pedal then the problem is the pedal.
