I bought Shift 3 Projection Alarm clock but i didn't find a manual inside, I don't know how to use it.
1 - How to turn on the projection?
2- How to turn on the radio
3- How to adjust the alarm clock
There is a DC 6V/0.3A outlet in the back of the Alarm clock, what should I do with it? do I have to use with the batteries at the same time or what?
Please halp and thanks in advance.
Moataz
SOURCE: Shift 3 Projection Alarm clock remote cannot open
There are four small phillips head screws that hold on the back cover. Just take a small phillips screw driver, unscrew the screws, remove the cover and insert two (2) AAA batteries. My problem is that the main unit does not recieve the outside temperature from the sensor.
SOURCE: Did not receive manual
go here and look for your model
http://www.lacrossetechnology.com/support/manuals.php
SOURCE: Remote signal not received by Shift 3 projection alarm clock
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
