Hi
The LED should be blinking red not green on a magic delux. The only green light is the boiler light for warming up or ready. If its the brew unit light it means its missing.
Open the door on the right. The brew unit is the thing with the handle that has the “press” on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
I have the green temp light and the far left green light on. But it will not brew any coffe after i cleaned the unit. I am baffeled. Beans in hopper and water full. ANy suggestions?? I have taken out side unit and clean it and reinstalled.
When the green templight is blinking it means that it is overheating. Turn the machine off and wait till th temp has dropped. Usually this problem is owing to a leak somewhere... look for water coming out of the machine.
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen A2 slightly.
