When I go into my verizon webmail I cannot get the message to come up on screen it just beeps or the big red x comes up in the tool bar. It has been doing this the past week. What can I do or what am I not doing? If someone send me something to forward I cannot do this either. The big red x comes up in the tool bar.
you need to teach the webmail what you regard as junk.
When you open the email message there may be a junk option at the top of the screen. When you tell the webmail the message is junk it should put it either in a spam folder or a junk folder and remember your request for mail sent from that email sender.
As I do not know the exact webmail I can't fully advise fully but most email services have a junk option. You then can go into the junk folder or spam folder in case an email message you wanted goes there by mistake and then you can un junk the message or move it back to the inbox. Be aware that the junk folder will fill up with junk and needs to be purged (delete all junk emails) every so often
You probably have setup a POP access on your Thunderbird to download your mails from your webmail. POP will download all of your message from your wembail to your Thunderbird and will place all of these message in your Thunderbird's inbox. Regardless if those message where sorted in different folders in your webmail.
In order for your mails to stay on your webmail you need to enable a setting in your Thunderbird that will leave a copy of your messages in your webmail. You can follow the steps below to check this setting:
On your Thunderbird
1.) Click Tools
2.) Click Account Settings
3.) Click Server Settings underneath the account that you setup.
4.) Verify that 'Leave messages on server' is checked in the server settings section
I get a green arrow when I send to people.
The green arrows turns into a checkmark, when the message is delivered.
With Verizon people this is usually within a minute or so, of course unless my friend has his phone powered off - which he will do, then I don't get a checkmark until his cell gets the message.
With Non-Verizon people I don't get a green checkmark until a day later, must take longer to confirm they got it from another cell company.
The RED X is normally what I get when I try to send to a landline or an invalid phone number, or if I try to send a message - while my phone was getting an incoming message..or to someone who has text blocked. The RED X means it did not go through at all. I will re-send these if I know it's a cell phone that can get text. Then I usually make it to green arrow/then green checkmark.
>lets check this option
>open outlook tools>account settings>select the account >click change>Advance tab>leave a copy of message on the server >apply and OK and continue with account settings wizard
>this is only applicable to pop accounts
and emails which will come after checking the option will remain on the webmail inbox
try this
right-click the menu bar and check 'Web assistant'. the Web assistant should now be showing on the tool bar. click on it and uncheck 'Block ads on this site'. this works for me in yahoo mail and also solved a problem i was having with my website's webmail account (MailEnable WebMail).
if this solve your problem, please rate the answer
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
