My washer fill cycle isn't stopping and the water overflows. What part do I need. It is a Whirlpool LSC8244eqo - Heavy Duty Super Capacity Plus - 8 Cycle 2 speed. Thanks!
Heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
When I took the control panel off by removing two screws, I found that the tube had come off the water level switch/part; so a very simple and cheap fix. I did have to use a wire to clamp the tube onto the switch/part to keep it from coming loose. Thank you!
