Leviton 1451-2ACP Grounded Quiet Switch Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace the light switch in my bathroom.
I need to replace the light switch in my bathroom. The faceplate is metal, and the switch doesn't show a grounding screw (leviton 01451-W). The replacement switch I found has a grounding screw (levinton 01451-2W. Are these equivalent switches?
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Mar 28, 2010
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
910966
Points
7895
Yes there the same type of switch,,just one is more up to date than the old one
1helpful
Tying into existing groundless knob and tube to run a couple fixtures and one outlet. Grounds?
Being as it is in the bathroom, there should be a cold-water metal pipe near. Attach a green conductor using an approved ground clamp. Run the wire to the outlet you want to ground. Attach to the box (if metal) then attach to the receptacle. If you can't get a ground installed as described, you could protect all the items (ceiling light and light over the sink) with the GFCI. All you need to do is feed the two items from the load side of the GFCI instead of the line side. This provides "people" protection as the GFCI function does not require a ground to detect the imbalance between the "hot" and the "neutral". This does not provide "equipment" protection.
I just replaced the 2 light switches in bathroom they still dont work
you need the critic checked,a om meeter is need
Apr 21, 2012 • Home
Hi i have a problem with my clarion dfz675mc the lights are not working the volume when i turn it louder is not working they only work when i push the face of the radio inwords and then when i let go the...
this deck has a detachable faceplate right? what you need to do is take the faceplate off and you will find 6-12 gold pins or strips of metal, you need to take rubbing alcohol and a q-tip and clean the contacts on the faceplate and on the deck side, also if the metal strips are only mounted on one side you can take a sewing needle and bend them out slightly, not too much because you could break them off though, if this helped you, please leave posative feedback thanks :)
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
2helpful
The face plate does not light up anymore on my Jenson CS2010X so I can't see the stations. How to fix this?
You might not be able to fix this problem. But first, here is a sugestion you can try. Remove the faceplate and inspect the metal contacts on both the deck and the faceplate. Each contact operates a different function of the radio such as providing power to illuminate the faceplate. Make sure no contacts have been broken, pushed in, or have corrosion. Once they all look good, replace the faceplate and see if it lights up. If not, its an internal problem with the unit and should be professionally repaired or replaced.
If the switch has only two terminals besides the ground, then yes, they are equivalent. BUT, do you have a ground wire? If this is an old house without a ground wire you have been lucky with the metal faceplate, especially in the bathroom. The new switch is no more dangerous without a ground wire than the old one was, but there is a reason they put that ground lug on there. If you don't have a ground wire, get a plastic faceplate.
2helpful
Wiring motion sensor for bathroom lights SL-6107-WH need to know what color ires are? BLK,Brn,Red,Grn
OK .. this sounds european .. but as I understand it ,,, the black would be power connection .. the brown would be neutral connection .. and the red would dgo to the light being controlled .. the green always connects to everything metal
If there is no neutral wire in your switch box to connect to ,,. then you will need to get a dimmer that does not require a neutral connection.
Please Vote !!
Need a faceplate for the timer
this is a common item. I would try a home depot or lowes first then an electrical supply house. or go on line to intermatic.com
Pioneer deq 7600 display went black today the eq works fine.
the faceplate contacts may need to be cleaned. remove the faceplate, and using an eraser, clean the metal tabs on the main unit and rear of the faceplate.
If this doesnt remedy the problem, service is required. May be the light unit in the faceplate.
3answers
Moisture on bathroom exhause vent
the fan is pulling too many cfm (cubic feet per minute).you can replace the switch of the fan with a potentiometer type switch (this works like a light dimmer)you can reduce the speed of the fan,or you can use a couple of synthetic fiber filters to trap the condensation.good luck
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
