20 Most Recent Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Questions & Answers
3answers
Same problem, when lights are on they flicker
could be a faulty batch. If all wiring correct then it must be the timer
5/28/2020 12:20:18 AM • Intermatic Inc.... • Answered on May 28, 2020
3answers
Intermatic outdoor can't reprogram. display reads NoOp
Les, First thing to do is to change the battery and see if the timer will allow you to reprogram it. Sometimes these timers will fail, as some models have a known history of failing fairly often.
NoOp, means non operating within the Intermatic line of electronic timers, so in order to see if the unit has failed or is just malfunctioning, due to a weak battery, remove the existing battery and install a fresh, new one.
You can remove the existing battery by flipping down the front switch panel and removing the battery tray with either your fingernail or a small flat bladed screwdriver. As your timer is showing the NoOp, you don't have to worry about losing your programmed on/off cycles, so you can take your time. Normally, if you're changing the battery, you get about 30 seconds to do this with some models of Intermatic timers, or you'll lose the settings. The newer models store the program regardless of how long it takes to change the battery.
Once you've replaced the battery, press the Reset button on the timer and allow it to refresh. If the NoOp is gone, just reprogram the timer with your on/off cycles and days and you're back in action. If the timer doesn't clear, you'll likely need to replace it, as it could be damaged and will not be able to be programmed again.
Usually, changing the battery and resetting the timer works about 60% of the time for me, as I've installed thousands of the various Intermatic timers in customer's homes over the years.
Hope you find this Very Helpful and best regards!
3/26/2020 8:21:31 PM • Intermatic Inc.... • Answered on Mar 26, 2020
My GE Time Switch 15132 problem
I have this timer and while it has power, it does now allow me the program it anymore. The screen shows all 8’s
6/11/2019 7:19:17 PM • Intermatic Inc.... • Answered on Jun 11, 2019
Installing utilitech in wall countdown timer
None of the answers are helpful. First, this is a question about installation and not operation so clpalmer976 is worthless. And no, if you read the question it was not a 3 way switch. If you hook it uplike ridley says, the light is not powered. Read the question. The red wire powers the device. The problem is "If I connect the red to the white, the switch will work in a clicking, pulsating fashion." The red has to be connected. The last suggestion, there is on info on unitech anything on the site. They are all somethings that can't read and make this site especially worthless.
6/10/2017 11:55:15 PM • Intermatic Inc.... • Answered on Jun 10, 2017
2answers
Intermatic EJ351 programmable light timer, red light blinking, light cannot be operated with timer or manually; I've replaced the light bulb with no difference in activity. thanks.
Open following for product manual and reset instructions:http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej500EJ351 is for incandescent light bulbs only and comes with 1 year limited warranty If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/8/2016 3:51:27 PM • Intermatic Inc.... • Answered on Oct 08, 2016
2answers
Manual available at:http://waterheatertimer.org/Intermatic-ej500c-manual.pdfhttp://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej500Ej500 is for incandescent bulbs only and for loads no farther than 100' feet away.Replaceable batteries last 3 years, timer comes with 1 year limited warranty.Use ST01C or Ei600 for CFL and LED and motor loads located within 100' If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/4/2015 1:27:38 AM • Intermatic Inc.... • Answered on Mar 04, 2015
2answers
Replace et724-A with new digital timer 15313
You are install GE 15313 timer Open following link to identify timer http://waterheatertimer.org/GE-timers-and-manuals.html#1531215313 timer does not require Neutral wire.The timer you are replacing has neutral wire (White wire)So replace timer wires 1:1 except do not connect timer to white neutrals.Keep in mind the 15313 is for incandescent lights only and is not for CFL or LED lights.If you want timer for CFL, then install one of the other timers shown on page. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/4/2015 1:26:14 AM • Intermatic Inc.... • Answered on Mar 04, 2015
I bought an Intermatic ej500 timer to use in a 2 gang outlet. The ej500 timer is meant to control my porch light. I have outdoor floodlights that are controlled by a toggle switch next to my Interma
Check if the white neutral wires came loose in back of box. Pull them out and re-install with new wire nut. http://waterheatertimer.org/How-to-wire-EJ500-timer.html#LR44 Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/3/2015 6:15:47 AM • Intermatic Inc.... • Answered on Mar 03, 2015
When hitting the next/on/off button, it dims the lights vice turning them off???
The EJ500 is rated for incandescent (resistive) bulbs only, and not LED CFL etc. Max distance between light and timer is 100 feet and wire cannot be underground. Replace with ST01 timer, or Ei600 timer... these timers are rated for any load (resistive or inductive), and are programmable or dawn-dusk... 7 day... single-pole or 3-way http://waterheatertimer.org/Programmable.html#st01 Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/17/2014 6:21:38 AM • Intermatic Inc.... • Answered on Nov 17, 2014
How do I programme time switch Hl03705/ ecorex d11 very difficult
See if manual appears among manuals/ or arlec manuals on following links: http://waterheatertimer.org/Woods-timers-and-manuals.html#arlec http://waterheatertimer.org/Woods-timers-and-manuals.html#13568 Attach photo of timer Gene If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
9/28/2014 10:34:32 PM • Intermatic Inc.... • Answered on Sep 28, 2014
Produtools.com
8/12/2014 10:23:24 PM • Intermatic Inc.... • Answered on Aug 12, 2014
0answers
Just bought my house and the porch light is
Don't forget to reset timer after replacing battery:Copy following link to identify timer and download manual:http://waterheatertimer.org/Intermatic-timers-and-manuals.htmlIf timer does not function after reset, then buy new timerEJ500 is rated incandescent bulbs onlyGeneh If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
10/6/2013 2:12:19 AM • Intermatic Inc.... • Answered on Oct 06, 2013
PROGRAMING SWITCH TIMERS
1) Copy following links to help identify timer and download manual:http://waterheatertimer.org/Intermatic-timers-and-manuals.htmlhttp://waterheatertimer.org/GE-timers-and-manuals.htmlhttp://waterheatertimer.org/Woods-timers-and-manuals.html2) Add a comment and describe timer in detail, including what the timer does, and what buttons appear on timer face, and location of each button. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/16/2013 2:29:56 AM • Intermatic Inc.... • Answered on Feb 16, 2013
My Intermatic Timer EJ600 does not work. What am I doing wrong?
1) Copy following link to identify timer, and download on-line manualhttp://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej6002) Wiring for the EJ600 timer is identical to wiring for GE15312 single-pole or 3-way timer with neutral wire requiredhttp://waterheatertimer.org/How-to-wire-GE-15312-timer.html3) This unit does not require battery.Add a comment Feb 2013, and say what your wiring looks like, and what you have done so far for programming. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2/8/2013 9:12:36 AM • Intermatic Inc.... • Answered on Feb 08, 2013
0answers
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
107 questions posted
Top Intermatic Hardware & Accessories Experts
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Hardware & Accessories
Most Popular Question
need someone talk me in person
  • Hardware & Accessories
