I have (2) 06S15L7 dual 2ohm subs and 1 Cyclone 2000watt amp specs are 2x1000 wattsmax@4ohm -2x1500watts max@2ohm -1x3000watts max bridged@4ohm how do you suggest to wire them up?
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
The deck EQ, amp gain, and amp bass boost are all going to generally do the same thing, just at different frequencies. Depending on the deck, it's LF band in it's EQ may be 80-100Hz. The bass boost on the amp is probably centered at 40hz or 60Hz (or adjustable, if you're lucky). The gain adjustment on your amp is going to boost every frequency.
So what it comes down to is you are going to have to play with each setting a little bit until you get, what you feel, is the best combination. Here are my recommendations:Set the amp gain to 50% (where 100% is full max).
Set the deck EQ to 0 (aka nominal).
Set the bass boost to 0.
Adjust each setting individually with the system at a "decently high volume".
How would you suggest i adjust my lows on my deck - my gain on my amp - and the bass boost (0-6-12) on my amp? My subs are 3days old. Thanx!!!!!
speaker sucked in the box, when i turn it up, but the other one would keep beating., Not sure if my box my be the problem or what, any help would be appreciated?
Autotek 7150 amplifier
