20 Most Recent Kicker 06ZX750.1 Car Audio Amplifier Questions & Answers
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
8/1/2016 5:25:59 AM • Kicker 06ZX750.1... • Answered on Aug 01, 2016
3answers
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
8/15/2014 7:35:33 AM • Kicker 06ZX750.1... • Answered on Aug 15, 2014
Red and green light flashing
its broken. sell it for parts of have it fixed.
11/15/2013 6:59:43 AM • Kicker 06ZX750.1... • Answered on Nov 15, 2013
Power
USE PROPER GAGE WIRE CHECK ALL FUSES TO THE BATTERY,THE FUSE ON THE AMP,MAKE SURE YOUR CONNECTED TO ELECTRICALANNTENA POWER WIRE ON STEREO (ITS USUALLY BLUE WIRE OR OARNGE WIRE ON BACK OF STEREO)BE SURE YOU HAVE A GOOD CLEAN METAL TO METAL GROUND WIRE CONNECTED TO BODY CHASSIS///SOME NEW STEREOS HAVE DIFFERENT WIRES ON THEM FOR CONNECTING AN AMPLIFER BE SURE TO CONNECT TO THAT WIRE THE REMOTE AMP PWR WIRE
5/25/2013 4:12:19 AM • Kicker 06ZX750.1... • Answered on May 25, 2013
06 kicker zx750.1 fuses melted opened amp and 2 capacitors blown
Better off getting it repaired through kicker.....Most of the time you cant find parts for their amps online or anything. Was the amp 2 ohm stable????? Is it still under warranty????
3/18/2012 1:53:58 AM • Kicker 06ZX750.1... • Answered on Mar 18, 2012
2answers
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
1/30/2012 10:22:26 AM • Kicker 06ZX750.1... • Answered on Jan 30, 2012
0answers
The amp has constant power,
This amp likely has several capacitors inside that drain very slowly after being unhooked. If you keep monitoring the voltage, you should see it go down slowly over several minutes.
3/2/2011 4:06:39 AM • Kicker 06ZX750.1... • Answered on Mar 02, 2011
What is the REM for in between the power and
can you use a house subwoofer for a car cutting the power plug nd hooking the cord to pos and neg to amp
1/21/2011 4:03:32 AM • Kicker 06ZX750.1... • Answered on Jan 21, 2011
I just got a s12l7
ABSOLUTELY!!!!! 4 ohms is the load that all amps are designed to play at. A lot of amps will play at lower loads but that equates to more heat. Less heat means longer amp life!!!
12/24/2010 1:09:54 AM • Kicker 06ZX750.1... • Answered on Dec 24, 2010
Protection light on Kicker ZX700.5
Considering you just bought it, the amplifier itself is probably not the issue. Small chance it is, but we'll go with that a last resort. Have you hooked it up without any speakers connected? Does the light still come on? Describe all the connections you have made to amp (what came from where, and what terminals it is connected to.)
11/11/2010 6:41:11 AM • Kicker 06ZX750.1... • Answered on Nov 11, 2010
My amp zx750.1 turn on
transistors if this is not the solution then trash it
9/25/2010 1:20:47 AM • Kicker 06ZX750.1... • Answered on Sep 25, 2010
No bassin for me
new resistors it needs
9/25/2010 1:19:10 AM • Kicker 06ZX750.1... • Answered on Sep 25, 2010
Sub not working
there might be transistors that went bad
9/25/2010 1:16:56 AM • Kicker 06ZX750.1... • Answered on Sep 25, 2010
Hola por favor necesito el
debes revisar todos los transistores que no esten da?ados.se miden con un multimetro y se supone que midan de 500-700 ohmios
9/25/2010 1:15:07 AM • Kicker 06ZX750.1... • Answered on Sep 25, 2010
My amp turns on the goes into protect mode. it
you need to open it and check if there are no bad pieces
9/25/2010 1:10:56 AM • Kicker 06ZX750.1... • Answered on Sep 25, 2010
Hi i turn the amp on and the green light turns on
You need to check the wiring of the sub or the box. If you have done that successfully than look at the rca cables and the blue antenna wire running from your deck to your amp
9/9/2010 6:59:51 PM • Kicker 06ZX750.1... • Answered on Sep 09, 2010
Kicker 06ZX750.1 Car Audio Amplifier Logo
45 questions posted
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Car Audio & Video
Most Popular Question
red green light flashing
  • Car Audio & Video
