eMachines T6534 PC Desktop Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get my emachine to turn on. i changed the power unit but it still don't turn on. it is a desktop version
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Mar 22, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
14046
Points
171
Try to check if u r getting any power on the motehrboard
CONTINOUS BEEP WHEN COMPUTER IS TURNED ON
To do this properly I need to know which model your computer is - is it an eMachines MB.NBK09.003 Motherboard El1850 Desktop S775 G41T-Ad ? I need this to try to establish the BIOS seller and version. You might try finding the BIOS version by (continuously) tapping the F1, F2 or esc key (or possibly another)immediately after you turn on. The "splash screen" that appears aftrer you turn on may have some lettering which tells what key to enter the BIOS.
In the absence of this information here are two suggestions
EMachines that beeps constantly and won boot up
if it is the above it is serious and the computer will need serious (difficult) repair, or main board replacement or whole unit replacement (by which I mean new computer)
The other suggestion was about the RAM not being properly in place, but I doubt this as this usually gives a different beep code
19.January.2016
Power switch on my T 3042 pc don't work
Check all cables, Try another outlet, are you using a Surge protector/ Backup battery supply? Test the PSU for power output with a multimeter.
Emachine 1300g-02w wont power upfans , power supply ok
These are notorious for Power Supply units failing. The power unit is bad replace it with another one and the problem will be solved. John
Model 333cs How do you get to set up.
computers are all different for entering setup. f1 f2 f10 or f11... sometimes it's just the delete key that you hit .... do that as soon as you turn on the power... one should work
2answers
No power on my emachine
Open the machine - try to change the SMPS.
Hope the Power-oN button is not the problem.
Else there could be many reasons.
Emachine 5210 not working
how old is your emachine?? is your display in condition?? if so, your smps might've worn out.. this is what happens when the display is proper but u still don see anything on the screen..
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Emachine help
Hi. could be a few things
1st thing if theres no power going to the base unit, the power supply is gone will cost about £20 for a new one.
2nd thing it could be graphics card, memory needs refitting. ie take them out and refitting them usually fixes it.
theres a few other things it could be but less likely. i suggest trying the above..
have a great new year
John
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
