20 Most Recent eMachines T6534 PC Desktop Questions & Answers
To recover audio files lost from digital recorders, you can try this program called Digital Photo Recovery (also recover AUDIO and video files). If you are running Mac OS X, turn to Photo Recovery for Mac (also recover videos and audio files on OS X).
eMachines T6534... | Answered on Aug 02, 2013
This is typically caused by a power supply failure. Failing power supplies can have enough power to turn on lights and fans but not enough to start the computer. The power supply does not store any data so replacing it is a low risk and low cost effort. It is a very well documented process so search the Internet for "replace power supply" for more details. I hope this helps. Good luck!
eMachines T6534... | Answered on May 01, 2013
do you mean the processor fan that is located near on the left top corner on the motherboard? if that stopped working then turn of your pc immediately. probably the cpu overheated. if that fan does not work replace it immediately as it will burn the cpu.
eMachines T6534... | Answered on Jan 14, 2013
I have this disc, and will make a copy for You if You still need it.
webgal03
eMachines T6534... | Answered on Jul 22, 2012
check to see the video display specs for the game make sure you have the proper graphics needed for the game
eMachines T6534... | Answered on Jul 07, 2011
You will need to buy a adapter.Your computer shipped with ide inputs.
eMachines T6534... | Answered on Jun 18, 2011
The problem could be with your Graphics card.
1) Try the monitor on another PC, is it good? If yes
2) Try removing and re-seating the graphics card.
3) If on board graphics and so no graphics card, try a PCI graphics card in one of the spare slots
eMachines T6534... | Answered on Apr 06, 2011
ndobbins
Do you getting anything on your screen when you first turn on your computer. This will tell me if the problem is with the video card or something else on the computer.
Also what kind of monitor do your have CRT or LCD. If LCD do you have an old CRT that you can connect to the computer for testing.
Also does the computer sound like it is booting normally or does it not seem like it is booting up.
Issken
http://www.fixya.com/users/issken
eMachines T6534... | Answered on Feb 22, 2011
I rather fear that if you shine a torch into the SD slot, you will find the internl pins are bent or crushed.
If they are, your best bet is to obtain a 5.25" card reader and either replace it in the slot the old one came from, or if that is not possible, remove a dvd bay cover and put it in there
eMachines T6534... | Answered on Jan 25, 2011
Try taking the monitor into a shop to be repaired, shouldn't cost too much.
eMachines T6534... | Answered on Jan 15, 2011
No. You have a 32 bit CPU. It will not run 64 bit software. You need a 64 bit CPU first.
eMachines T6534... | Answered on Sep 13, 2010
boot up in safe mode and scan for viruses
eMachines T6534... | Answered on Aug 06, 2010
Recovery disks cost about £15, check what version of windows you have, you may be able to download that version of windows from a torrent site and use your own COA key to activate it.
eMachines T6534... | Answered on Aug 04, 2010
http://www.emachines.com/support/drivers.html
eMachines T6534... | Answered on Jul 30, 2010
try to check if u r getting any power on the motehrboard
eMachines T6534... | Answered on Mar 22, 2010
Schematics for motherboards can be different but most have a series of pins that those plugs are plugged into. Here is a link that will guide you through the process. The pins are labeled POWER/LED/SPEAKER if you look closely. Hope this helps.
eMachines T6534... | Answered on Feb 05, 2010
Hi, Have u tried removing the RAM and CMOS battery and then again put it.
eMachines T6534... | Answered on Jan 25, 2010
The most likely solution to this problem is to go to the computer manufacturers website and find the drivers for your flash drive and install them.
After this, your flash drive should work fine.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
eMachines T6534... | Answered on Jan 12, 2010
Unplug the power cord from the back. Press the power button to discharge the power supply. Plug the power cord back in and test the button.
eMachines T6534... | Answered on Nov 06, 2009
eMachines T6534 PC Desktop Logo
Popular Tags
33 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
emachine troubleshooting
  • Computers & Internet
