Teka DW6 Use And Maintenance Manual How To Fill The Salt
Page 8 is for salt.
SOURCE: LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
1. Unscrew the cap from the salt container
anticlockwise, which is located on the right side of the
inner box.
2. Load the salt into the container. Each time you may load 250g of salt, which can be used for 15
cycles.
3. Fill the water into the salt container until a small amount of water comes out(it is very important
when you use it for the first time).
4. Screw the cap back carefully.
Note:
1. Load the salt before the beginning of wash cycle so as to prevent corrosion.
2. Load the salt when the salt indicator light in the control panel is illuminated.
3. Only use dishwasher salt.
