NorStar M7310 Corded Phone Logo
Posted on Mar 16, 2010
Record greeting I am trying to rerecord the greeting for the voicemail. After 3 seconds, the phone displays "out of space" and says there isn't enough storage to record the message. I need to change this greeting ASAP.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Apr 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
17
Questions
0
Helped
6185
Points
21
What kind of voice mail system do you have? They all are limited to the amount of total storage available. It probably has one or more mail boxes that are full and using up your storage. If it is a call pilot 100 or 150 and you have call pilot manager access, you can click on "message usage" under the reports menu and it will tell you the current storage available. Hope this helps.
Bill C www.dyna-tech.us We also offer remote programming and tech support for the Norstar CICS, MICS and the Call pilot 100/150.
How do I record a mailbox greeting on Avaya 1408?
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1. Press the key%20messages.zoom50.png MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3. Use the soft keys to listen to and record your mailbox greeting.
ā€¢ Listen
Listen to the current greeting or the new greeting just recorded.
ā€¢ Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
ā€¢ More
Switch between the different sets of available soft key functions.
ā€¢ Submit
Submit the new recording as your mailbox greeting.
ā€¢ Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
Apr 28, 2014 • Avaya 1408
Voicemail change message
How To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
How To Record Your Alternate Greeting (Used when on vacation or out of the office.:1. Press the Check Voicemail key or press the Feature button, then 981
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the Choose softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting.
2helpful
How do I change voicemail greeting on Nortel Model T7316 phone?
feature 981
enter password
listen for promt to change greeting.
for main greeting
press feature 983
if 3 digit extensions enter 1020000 if 2 digit extensions enter 120000
press AA
press grtg
press 1
press rec
press ok to end recording
press ok
press rls
To Listen to the Greeting, press Play. To ReRecord, press RETRY. Press OK to accept Greeting.
22helpful
6answers
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
Problem setting up voicemail
Check the procedure is correct.
1 Tap Voicemail, tap Greeting, then tap Custom.
2 Tap Record when you’re ready to start.
3 When you finish, tap Stop. To review, tap Play.
To rerecord, repeat steps 2 and 3.
4 Tap Save.
Hope this helps
Regards
1helpful
I need to change the main company greeting
dial voicemail, when prompted for mailbox
99#
1234#
9
3 for AA
1 for day 2 for night
6 to modify menu
press star (*) pound (#) (you arent messing with selector codes
record greeting there. 21 to rerecord, 23 to listen
Make sure you press # to save when finished
1helpful
Rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
1helpful
Nortel Compact ICS 4
Hi Yolanda,
You did not mension what type of voicemail you have installed with the phone system so I'm assuming it is also a Norstar.
To record your Primary Greeting:
1. Press " Feature 9 8 1 "
2. Enter your password ( Default is 0000 )
3. Press " OK or * "
4. Press " Admin or 8 "
5. Press " Greet or 2 "
6. Press " Record or 1 "
7 Press " Prime or 1 "
Display should read " Record new ? "
8 Press " Yes "
Display shows " Record Greeting : "
9. At the tone record your Greeting
10. Press " OK or # " to end recording
2answers
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
10. Press the ChOOSE softkey
took this from a guide i have, might help you guys out
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
