Hotpoint aquarius cdt00 condenser tumble dryer
light stays on to say water needs emptying--but dosent
and ** hot air just cold
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
I also need help my new condenser keeps bleeping every 3-5 minutes saying h20 water needs empting but its not even primed yet as nothing is collecting
Can you tell me where on the dryer i can reach the weight switch please?
but where is the weight switch located do I have to replace it with a new one
