Following steps can fix your Issue
1. Please confirm you are able to print by connecting the printer to the Vista computer directly.
2. Click Start - select Control Panel then switch it to Classic View from left side.
3. Double click on Printers & Click on 'Add a Printer'.
4. Select 'Add a local printer' & Click next.
5. Select 'Create a new port'.
6. Select 'Standard TCP/IP Port' as 'Type of port' then click 'Next'
7. Enter the IP Address of the Print Server in the 'Hostname or IP address' field.
8. Uncheck 'Query the printer and automatically select the driver to use' & Cilck next.
9. Select 'Custom' then Click on 'Settings' on the next dialogue box.
10. On the next dialogue box, select 'LPR' as the 'Protocol'.
11. Under the LPR Settings put in any name for the 'Queue Name'.
12. Check 'LPR Byte Counting Enabled' then click on OK and next.
13. Select the Manufacturer and the Model Number of the printer. If it is not available then click on 'Have Disk'. Click 'Next'.
14. Check 'Set as the default printer' and click next.
15. Try to print test page, it'll print.
regards,
prakash
Testimonial: "Thanks prakash. Has done the trick."
