Lands Phones Logo
Posted on Mar 11, 2010
How to adjust speaker volume on the fujitsu phone
Topic: How to adjust speaker volume on the fujitsu f10B 0789 B001 23IVR DT24D telephone.
When I am called on the intercom, the speaker volume is too loud. How can I adjust this? Does anyone know where I can get a manual for this phone model?
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Mar 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
1434
Points
42
Go to settins and tone select a tone and it will show u a volume setting... :)
Magicjack problems
Volume is controlled at the Computer if the MJ is attached to the USB port. This means the Speaker Volume control (see lower right on your screen for the speaker icon) needs adjusting or the speakers volume control on the attach sound system needs adjustment. If it is a MJ+ that plugs into the Modem (or router) USB port or Cat6 line port; you can only adjust volume on your attached telephone.
5helpful
Increasse Panasonic telephone volume
You may download a copy of the manual here. To adjust the ringer volume, see the instructions on page 37. To adjust the voice volume during a call, press up/down-arrow.
How do i increase the incoming and outgoing call volume
(For Kyocera Oystr)
Menu / Settings / Sounds / (choose topic) / (adjust up or down with button on side of phone) / save.
Ringtone volume, earpiece volume, key volume, speakerphone volume, etc.,
can ALL be found and set in the settings/sounds menu, and adjusted to your liking.
6helpful
Please advise as to how to increase the VOLUME on my DECT 6.0 phone.
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
1helpful
HOW DO YOU CONVERT NEC ASPIRE PHONES FROM FRENCH TO ENGLISH?
The keyset’s display provides a 3-line, 24 character per line alphanumeric
display that displays various information for the telephone
either while on a call or while idle. You can change the contrast of the
display as well as the language used when displaying the prompts.
1.On an idle telephone with no BGM,
or .
Pressing either volume key adjusts
the LCD display.
If BGM is enabled for the phone, in
order to change the contrast, it must
first be disabled (CALL + 825) or it will
adjust the speaker volume.
1. Press + + the language
number to be displayed (00-12).
0 = Japanese 1 = English
2 = German 3 = French
4 = Italian 5 = Spanish
6 = Dutch 7 = Portuguese
8 = Norwegian 9 = Danish
10 = Swedish 11 = Turkish
12 = Latin American Spanish
To change the
displayed language:
To adjust contrast:
58
7helpful
2answers
How do i adjust display screen on nec aspire phone? Is too dim all of the sudden.
or .
the LCD display.
To change the
displayed language:
To adjust contrast:
58
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 • Cell Phones
DTerm80 phone, how to get language on display back to english
or .
the LCD display.
To change the
displayed language:
To adjust contrast:
58
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
