20 Most Recent
NEC Dterm DTP 16D-1 Corded Phone Questions & Answers
I have an NEC Aspire
1) pry off the top keypad cover 2) unlatch the clips in back of the screen by squeezing the arms together to release the display from the base 3) lift up the LCD display and pull forward to slide the hinges out to the openings and lift up and out.
Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
NEC Dterm 80 display
It took me forever to find out, but heres what you do.
with the phone hung up:
1) "Feature" then press "1"
2) then press "#", "*", "#"
3) lift the phone, then hang up
4) press "Speaker"
5) dial "700"
6) press "hold"
7) enter the name (I'm still trying to find out how to leave a space, or use aother character that the same number key has... ugh"
8) press "hold" then "Speaker"
then make sure it saves it in the directory
How to listen to voice-mail box ?
Press the voice mail button or dial the pilot for the voicemail, enter the password or ID your own extension (9+ext) on really old voicemails, then password, listen to the prompts or use the active buttons in the display.
How do I take off do not disturb
If you have a DTP-16D phone, I believe that device was used primarily on the NEAX 2000 system by NEC. If that is true, you can try the default DND cancel code: #8 (*8 sets it). Unfortunately, the system codes CAN be changed by the installer, so it could be something else. Please let us know if that works. Thanks.
