The laptop is about 5 years old running Winxp home.
Shut down normally last time is used it.
Power supply has light on it.
The battery has never lasted on it's own for more than about 15-20mins but has never been an issue.
When I turn it on the power light on the power button stays on, the power light and hard drive light stay on...all solid. The fan start for a second or two but thats it? Cold boot and restart several times but now help.
Have tried a few thing I found by googling....
Took the memory out and back in...no help.
Took out battery and power cord. Help power button 30secs then replaced power cord...then battery...no help.
Hope someone can help?
Remove the battery and just leave it off the computer, then plug in the power cord and try it. If it works with no battery...the battery is completely dead and you need to replace.
Testimonial: "Took out battery and plugged in power. I get the same thing...power button...power light...hard drive light are all solid."
Is the Targus ac70u the factory power supply and was it the same one you used to successfully boot previously? If it isn't and is a third party power supply, you may have one or two issues. Either it is not supplying enough power for the laptop or too much and/or the polarity on the tip could be reversed. The factory one is 65W I believe so make sure you are getting the right amount of wattage. If the aftermarket power supply has a voltage selector, make sure your setting is per the specs on the bottom of the laptop or the setting just above (i.e. if the laptop calls for 13.6 volts and your supply switches from 13 volts to 14 volts, leave it on 14 volts as the lower setting won't work right). Lastly, if it has a detachable two-prong tip, you might have the tip backwards which reverses the polarity of the positive and ground terminals in the tip so try switching that. Hope this helps!
The battery has not worked well for years? Only lasted about a year...same as the original power supply. Never had a problem till now. Current power supply is Targus ac70u.
you should know, battery live is 3 wears or 1000 cycles of charge/discharge. I think your battery is over. You may check battery in the BIOS if you have such sensor.
regards
Greg
