Installing part 903091-9051 in a wall oven Frigidare FEB24S2ASB
From advice I received here on the "FixYa" website (Thank you iwillfixforu), I am considering fixing my oven myself... I have a Frigidaire FEB24S2ASB that needs a new electronic oven control, part number 903091-9051.
Looking at the wiring, it looks like all I will have to do is plug in six wires that are color-coded. Am I overlooking anything, or is it really that simple?
I know this isn't directly answering your question, however, what "burned up" about it?
You can get just about every part that fits that oven from Sears PartsDirect. Control boards, bake elements, convection fans, switches, replacement glass... just about everything.
Unless the oven literally burned through the side/top walls, you're most likely going to save money by fixing whatever's wrong with it.
Even the clock/timer control board is only $164 for the OEM part.
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electricrange cavity and relay it to the oven's main control so it knows when to shut off the heating elements.
Hope this helps
Bob
The electronic oven control has gone bad. The repair is a lot less expensive than the replacement of the whole stove. Part number is 903091-9051 at about 165.00 retail. You can fix rather than replace whole stove. Hope this helps.
Unfortunately I was unable to find the manual in my database. But still found the solution you can click on these links and refer to the instructions :
your model says its a 24"
but the hot surface igniter for oven is bad
it should have a seperate one for broiler
check here on fix ya ( hot surface igniter)
