Hello- First of all, congratulations on getting it out, apart, and back together again! There are two types of switches for this cooktop. One for the dual, other three are single. Wires can be a trick sometimes. Replacement switches look different sometimes, but work the same. If part is correct, check wire connections at contact points. Lightly crimp any loose ones. Partselect.com has the wiring diagram for JED8430. Let me know if this info helps- have more if needed. - Thanks- ED
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
